Old 05-12-2006, 11:50 PM   #1
gotmud
gotmud's Avatar
Question front end id help needed
Can anyone help identify this front end? Someone told me they appear to be from a 73-87 C10. Right now it is on a 64C10 I bought from an estate. Any ideas? I want to put on drop spindles and springs but want to validate the donor first.....
Thanks!!!!!
More pics at:
http://www.whitehorsetechnologies.co...frontendid.htm
Thanks in advance folks!
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
Old 05-12-2006, 11:52 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: front end id help needed
It's a 73 and later
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-12-2006, 11:55 PM   #3
bigblock73
yeller
bigblock73's Avatar
I agree ^^
bigblock73 is offline   Reply With Quote
Old 05-13-2006, 12:15 AM   #4
gotmud
gotmud's Avatar
So if I order drop spindle for a 73 will they fit or do I have to worry about wheither or not there is something different between the 73 and a 86???
Glenn
Cumming, Ga
Old 05-13-2006, 12:34 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
You will need to check the thickness of the rotor. If it's 1" thick it standard, if it's 1.25" thick it's and HD. They use a different spindle...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-13-2006, 01:01 AM   #6
gotmud
gotmud's Avatar
they are 1"......are they the same on all year models?
Glenn
Cumming, Ga
Old 05-13-2006, 01:05 AM   #7
Oldschool68
Hellion
Gotmud call up CCP or check em out on the net to see if they can help you out!!
Oldschool68 is offline   Reply With Quote
Old 05-13-2006, 10:56 AM   #8
bigblock73
yeller
bigblock73's Avatar
73-87 C10 drop components interchange between all years, only difference is the rotor thickness, as Ken mentioned.
Old 05-13-2006, 12:11 PM   #9
gotmud
gotmud's Avatar
Thanks guys!!!!!!!! Ill send pics when she the rake is done...
I got a set of Cragar S/Ss to shoe her up with so a dropped front will look nice I hope.
Glenn
Cumming, Ga
Old 05-15-2006, 02:26 AM   #10
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Gotmud -
Are you going with 2 1/2" or 3" spindles?
It's gonna look good if you can reach your goal. Your plan sounds good, but I didn't see where you were gonna drop the front. Sound like scope creep to me.
BTW, when does 'annoying the neighbors' start.
Good luck with your project.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 05-15-2006, 10:47 PM   #11
gotmud
gotmud's Avatar
I dont know boxrodz....is there that much diff between 2.5 and 3?
What da ya suggest? Are drop spindles from one vendor the same as another?
Glenn
Cumming, Ga
Old 05-16-2006, 12:12 PM   #12
82c10
needin' money
1/2"
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 05-16-2006, 12:22 PM   #13
bigblock73
yeller
bigblock73's Avatar
People have run into clearance issues when using 3" spindles and 15" wheels. I am not sure about your W&T setup, but it is something to consider if running 15" wheels.
If I could do it over again, I would have gone with a 2.5 spindle and 2" spring.
Old 05-16-2006, 12:47 PM   #14
gotmud
gotmud's Avatar
what is a W&T setup? I am running 15" wheels
Glenn
Cumming, Ga
Old 05-16-2006, 12:52 PM   #15
bigblock73
yeller
bigblock73's Avatar
Sorry, Wheel & Tire
Old 05-16-2006, 02:39 PM   #16
boxrodz
boxrodz's Avatar
It depends how low you're trying to get at ride height. For the extra 1/2" drop with 3" spindles, you're gonna run into clearance issues between the LCA and 15" wheels as Jeff mentioned. But, many just trim the gutter lip of the LCA to solve the problem. Others run a larger wheel, so clearance should no longer be an issue. (Although Scoti mentioned in a previous post that he's running 18x8s in front and had to trim the LCA.) I haven't heard of anyone running into this problem with the 2 1/2" drop spindles.
DMJ, Western Chasssis and Bell Tech all make decent drop spindles with pretty much the same specs.
boxRODz
Old 08-18-2006, 05:57 PM   #17
gotmud
gotmud's Avatar
I think I measured wrong...it looks now like its 1.5". The pads were an exact match for a 73C10 pads at Autozone. Also now that I measure it I wonder if its already got lower springs. They only have 10" of travel...is that right???
Pics here: http://cdrawdy.blogspot.com/
Glenn
Cumming, Ga
Old 08-18-2006, 06:02 PM   #18
gotmud
gotmud's Avatar
Whats the URL for CCP? I cant find them.....
Glenn
Cumming, Ga
Old 08-21-2006, 03:26 PM   #19
boxrodz
boxrodz's Avatar
Boy, that is a wide rotor. With a 5 on 5 pattern, I'm not sure where those rotors came from. Maybe you could have the autoparts store do a reverse lookup on the number stamped on the rotor cap.?
Maybe, he's referring to http://www.chevy-classic-parts.com.
boxRODz
