Old 05-13-2006, 11:14 PM   #1
69oldie
Never too many LONGHORNS!
69oldie's Avatar
Question How wide is......?
How wide is a factory 1971-72 C30 dually rear axle from wheel mounting surface to wheel mounting surface?
Thanks for your help in advance!
Jim "69oldie"
Always looking for N.O.S. parts for my 1968 Longhorn and Looking for an awesome 1969 Longhorn that deserves to be restored....of course with N.O.S. parts!!!
69oldie is offline   Reply With Quote
Old 05-13-2006, 11:54 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: How wide is......?
no answer... but long time no see. I was in your neck of the woods last month... bummer I couldn't remember your screen name, I would alooked you up.
Maybe next time. I HOPE to go back out there in Aug.
Old 05-14-2006, 09:51 AM   #3
pumpkin
pumpkin's Avatar
I have an eton dually, and its 63"
pumpkin is offline   Reply With Quote
Old 05-14-2006, 05:14 PM   #4
69oldie
69oldie's Avatar
Question Re: How wide is......?
Longhorn Man....thats too bad . Pumpkin, what year is your dually truck? For some reason I would have thought that a dually rear Eaton axle was wider than 63" ? My single rear wheel Eaton HO72 I have (Yes I have a couple spares!) are 65" from wheel mounting surface to wheel mounting surface. I wonder if there is a narrow and a wide dually versions?
Old 05-14-2006, 10:54 PM   #5
Longhorn Man
That sounds about right to me. On these trucks the extra wheels were tucked in, not sticking out.
Old 05-21-2006, 05:32 PM   #6
pumpkin
pumpkin's Avatar
The housings are the same, its the hubs that are different. I have 5 five eatons. one 4.10, three 4.56, and one 5.13.
Old 05-22-2006, 02:44 AM   #7
4x4Poet
[Thread Hijack]
Is it possible to convert a DRW Eaton H052/72 to disc brakes? Blackbird, for one, offers a kit for SRW Eatons, but with the DRW wms being less than SRW axles, wouldn't the supplied SRW rotor be too deep in the *hat* and thereby hit the backing plate? IOW, the backing plate on SRW and DRW Eatons are the same and mounted the same, right? But the back of DRW hubs are further inboard than the back of SRW hubs?
Anyone have experience sourcing drum brake parts for DRW Eaton H052s? Same stuff as 11" brakes on SRW Eatons?
[/Thread Hijack]
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 05-25-2006, 07:57 AM   #8
pumpkin
pumpkin's Avatar
I've got an eaton in my 72 blazer. I converted it to disc brakes, used caddy calipers, front rotors, made my own caliper brackets, and chaged it to six stud, so I could keep my mags and tires. For caliper brackets you can also use front 4X4 caliper brackets, and weld them on to the housing, direct, or by means of a flange and bolt set up. By the way what does DRW and SRW stand for? Single and dual wheels?
Old 05-25-2006, 02:32 PM   #9
Longhorn Man
Single and dual wheels... that is correct.
