05-14-2006, 11:58 PM | #1 |
Back In Action - With Questions
Greetings Everyone,
I hope all is well. I have not posted in a while. Went overseas last year and have been trying to catch up with life since I got back to the states. I have pretty much finished up my 72 Burb (pic attached) and am moving on to two more Chevy projects, a 68 Chevelle for my wife and a 70 C20 for my daughter. I have a few questions for some of you experienced mechanics out there. See below: 1) My 72 Burb has a late 90s based 350 with Edelbrock RPM heads and an Edelbrock EPS manifold. Where the manifold meets the bllock at the front of the engine I used Black RTV per the manufacturers instructions. The area of the RTV keeps getting dirty/greasy and when I spoke to a friend he said that a small amount of engine oil is probably weeping from that area. I clean it off and 2000 miles later its all dirty and greasy again. Has anyone else experienced this? 2) I am about to rebuild a late 60s 307 and have been looking for some really good valves for the stock heads. They take a 1.720 intake and a 1.50 exhaust. Manley carries some severe duty valves that I would like to get but the 1.720 only comes in a +.100 length. Is it OK to use a +.100 length and should I get an exhaust valve that is also +.100 in length so that they are the same? Will I need to get longer pushrods? I plan on using roller rockers and a mild performance hydraulic camshaft. Thanks, Jeff
72 C10 Burb 350 700R4 70 C20 LWB 350 Crate TH400 68 Chevelle |
05-15-2006, 12:44 AM | #2 |
Designated A-hole!
Re: Back In Action - With Questions
No help on your questions, but that's a good looking 'burb.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
05-15-2006, 01:20 AM | #3 |
That's a gorgeous burb! The cowl hood looks better on it than I would have imagined.
On the RTV issue, just redo it. Let the new RTV set for 24hrs before starting engine. Other board members have said that RTV needs 24hrs to set hard enough to resist oil. You could also use The Right Stuff, instead. It's rubber based for a better seal but probably less heat resistence than black RTV. But the front of the intake has no need for a sealant with high heat resistence which is why black, vice red, RTV is OK there. I like to use high quality FelPro intake gaskets with the *blue* sealing rings around the ports. I also use Gaskacinch on the gasket around the ports. Peals right off next disassembly.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 05-15-2006 at 01:21 AM. |
05-15-2006, 10:41 AM | #4 |
Post Whore
What a beautiful Burb! Post some more pics if you can. I would agree that pulling the intake and resealing it is your option.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
05-15-2006, 10:57 AM | #5 |
I think a nice upgrade for the 307 heads would be a 1.84 intake from a 80's something 305, gives you a new seat surface and if you back cut the intake it will flow better, You will likely need hardened seats put in the exhaust.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
