Old 05-15-2006, 03:21 PM   #1
ChevyDude
For those doing manual to Auto, can someone clarify flexplate bolting please.
The flexplate has recessed area's where it bolts to the torque converter...just so I don't bolt it in backwards I thought I'd ask the dumb question. Maybe this will be helpful for others as well.
In the first picture, should this be the side out (away from the engine) when it is bolted the crank? Or is it the second picture that should be facing you when bolted to the crank?
Thanks...this old tile setter needs some help mechanically from time to time!
ChevyDude is offline   Reply With Quote
Old 05-15-2006, 03:29 PM   #2
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
Re: For those doing manual to Auto, can someone clarify flexplate bolting please.
In the middle of any flex plate there is a small tapered flange. the taper faces away from the crank shaft which should put your torque converter on the raised side of those recesses.
Oldtruckfanatic is offline   Reply With Quote
Old 05-15-2006, 03:35 PM   #3
TugOwar
yep. the recesses "reach out" to meet the torque converter, if that makes sense.
TugOwar is offline   Reply With Quote
Old 05-15-2006, 04:24 PM   #4
ChevyDude
Yep, perfect...both responces tell the story well!! Thanks guys!!!
Old 05-15-2006, 10:46 PM   #5
mrein3
mrein3's Avatar
You need new bolts too to bolt the flex plate to the crank shaft. Your manual ones are too long. Ask me how I know.
I was lucky. I had a 350 with no home sitting in the shop when I was bolting my th350 in place of my 3-speed manual. The flex plate was still on the spare engine so I had the right bolts.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 05-16-2006, 01:35 AM   #6
ChevyDude
I knew that, but thanks. New bolts from ARP are on the way from Summit. I also needed Metric bolts to bolt up my Dacco torque Converter.
Old 05-16-2006, 08:00 AM   #7
68C15
blood type; Retumbo
68C15's Avatar
you can get them from just about any tranny shop for about a buck each.
68C15 is offline   Reply With Quote
Old 05-16-2006, 10:46 AM   #8
ChevyDude
Good tip there...I paid a lil' more coming from Summit...oh well.
