Remove ac components?
My truck originally came with ac,but PO removed ac compressor. I have the condensor/evaporator..etc. SHould I remove them or try to complete the system again?
#2 | |
Re: Remove ac components?
Respectfully
Billy ![]() ![]() 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! ![]() ![]() ![]() I'M IN THE MARKET...AS IT WERE! |
i'm going to try and get my oraginal up and running all there but the compressor. i understand there are better systems avalible reasonable ,but wheres teh challange in that
common sense isn't so common anymore |
I'd rebuild the original. It's as good as the newer systems, may not be as efficient but as functional. If you believe you need empty space under the hood, more noise in the cab and foggy windshield in the morning then the newer systems are the way to go. If you like the way the original system looks under the hood and an ac and heater that works very good, then that's the way to go.
So, basically what you are all saying is I should one way or another complete the system. Not remove the remaining pieces.
![]() Join Date: May 2005
Dance with what brung ya..... P Bryant
An hour and a test light, I have mine working after decades of non use...... but I got lucky |
