05-16-2006, 04:33 PM | #1 |
70 suburban rear end swap question
I am about to purchase a 1970 suburban. The front brakes have been changed to five lug disc and the rear are still six lug drum.
Would like to change to five lug? what are my options using a donor rear end or I have heard about only swaping the shafts and drums. Is this possible? Also, Heard that the 71-72 rear ends are of a different width than the earlier ones too, is this a myth or reality? thanks,
Soon to be selling all but one, or two... Depends on what the Boss has to say....... 67 GMC Shortbed 454 Project more junk and most of it is for sale |
05-16-2006, 05:03 PM | #2 |
Re: 70 suburban rear end swap question
i've heard late '70s early '80s cadillac rear ends might be a good option. they have the disc brakes and 5 lug truck pattern. don't know about the width, though.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
05-16-2006, 05:18 PM | #3 |
You might want to crack the rearend cover and see what gear ratio you have and what shape the gears are in. If in good shape and correct ratio, I would just swap axles and drums (about a 1 hour swap). If not in good shape, start searching for a donor rearend. I got lucky and PO had the entire rearend rebuilt with new gears and and a new posi ($1800!!!). So I just bought an Early Classic's axle conversion kit, instead of getting another rearend.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-16-2006, 05:29 PM | #4 | |
Nate |
05-16-2006, 06:40 PM | #5 |
My 1970 truck rear end is the same width as a 71-72, some may have the wider rear and some may be the 69 and older width. If you have the wider one, a simple axle and drum swap will do it, else you can have the old axles redrilled, or swap entire rear end.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
05-16-2006, 07:01 PM | #6 |
its all about the +6 inches
Green got it right... if it's an early 70, narrow, late 70, wide axle.
05-17-2006, 01:01 PM | #7 |
Thanks I ahve access to a 72 rear end that might be in good shape... Truck was rolled over on roof and back down again. If it will firt I might jsut swap axels and drums.
thanks agaain, I had always thoughtt he wider rear axel thing was a hoax. thomas
05-17-2006, 01:02 PM | #8 | |
Measure the rear end? or is there a date code associated with the vin? Thomas
05-17-2006, 02:38 PM | #9 |
To my knowledge, no one has figured dates to vin yet, I doubt it can even be done acuratly. If you have the sticker in the door jamb, you can guestimate... but the only way you can be certian, is to measure it out.
05-17-2006, 05:24 PM | #10 |
What is the width of the narrow and wider rears?
1997 GMC Sierra Ext 1965 Mustang |
05-17-2006, 05:49 PM | #11 |
56 inches
57 1/2 inches |
05-17-2006, 06:20 PM | #12 |
thank you
05-19-2006, 01:26 PM | #13 | |
Is tere a standard way to measure them? Inside of backplates, front of drum to front of drum? Any help would be apppreciated? Thanks.
