05-16-2006, 07:14 PM | #1 |
TPi
I just bought a 92 Z28 TPi unit for my 69 GMC stroker project.
Problem is, the guy would not part with the harness and ecm. Now I'm searching for these items. I've looked at stock but am told I need a chip burned for my application. I've also looked at aftermarket but Accel units start at $1600. I'm not looking for a drag truck, just a good performing daily driver. Any suggestions would be appreciated. Thanks!
69 GMC 3/4 ton LWB 383 TH400 Dana 60 '84 300ZX '79 Nova (for sale) |
05-16-2006, 07:39 PM | #2 |
Re: TPi
you have a few options with the ecm chip and the harness, 1st option is go to the salvage yards and find the ecm and harness. It can be hard to find a good harness because people always chop them up behond useage in salvage yards. You can find ECM's on ebay. Personally I would find a used ECM in a salvage yard or on e-bay or perhaps some f-body fourms. Then go aftermarket for your harness like painless wireing. The chip you can get custom taylored for under 200 buks try tbichips.com. I am building a TBI project right now and one thing I can recommend is deffently do your homework, search all over the web and get as much info as you can that is what I have done. In fact I have made a big 3 ring binder for all of my conversion information that I can refer to. I plan on posting my detailed TBI information as soon as mine is on the road.
Good luck
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's 1970 K5 TBI conversion lifted etc SOLD 1968 C20 camper truck SOLD “To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder |
05-16-2006, 07:55 PM | #3 |
Re: TPi
Jason, That sounds great, can't wait to read your post on your TPI conversion. If you can, just remember to dumb it down for guys like me.
If you keep and open mind you never know what might drop in. 1970 Chev C10 SWB, "250 turbo thrift" |
05-16-2006, 08:21 PM | #4 |
Re: TPi
Go with a painless TPI wiring harness. Pretty easy (as long as your power wire gets constant power while cranking....ask me how I know )
I think you can pickup a ecm from the parts store for like $100. I wouldn't trust a salvage yard junker....they're somewhat fragile. I'm running an 87 tpi engine, so I didn't have to deal with vats....but...another thing that you can do is get an "emulator" that plugs in to where the chip goes and you can esentially just reflash the emulator with the use of a laptop. I'm planning on getting one eventually once I get to doing some engine mods (cam, heads, etc). Go to thirdgen.org to read up on all of the computer chip BS you could ever dream of! Good luck! |
05-16-2006, 09:23 PM | #5 |
Re: TPi
I've got a shot at a Accel Gen 6 ecm (74022) and harness but understand it's DOS based.
Anybody have experience with one of these?
05-16-2006, 09:50 PM | #6 |
Re: TPi
why do i get the feeling all this pci, tbi, ecm, chip stuff will forever and always be over my head?
good luck with the conversion you guys. |
05-17-2006, 11:35 AM | #7 |
Back in the sticks
Re: TPi
Personally, I would go with a custom harness and ECM. I had mine done by Jims Performance. Its a little more expensive, but there's the whole warranty thing. My ECM crapped out after a year, and he replaced it for free. The harness is custom to your application and you just plug and play. Mighty easy. Good luck and keep us posted. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
05-17-2006, 12:23 PM | #8 |
Re: TPi
You can buy a new or used ECM here: http://tpiparts.net/82_92_ecm_and_prom
They also have programming services. So you can have them eliminate the VATS,and whatever else needs to be done.
'67 C10 Short Stepside 5.0TPI/700R4 |
05-17-2006, 01:44 PM | #9 |
Re: TPi
ackattack, I have not heard of the emulator, sounds interesting, I'll check the thirdgen web site.
red71, Custom would be nice but what I'm seeing is $1600 and up for a harness and ecm. Not really prohibitive but well beyond what I'd budgeted. CochinoFilipino. Thanks for the link, I'll check it out. Still like to know if anyone is running a Gen 6 Accel ecm???
05-17-2006, 03:11 PM | #10 |
Back in the sticks
Re: TPi
If you go to Jimsperformance.com I think the harness is $250 and the ECM is about $300 depending on the prom you need. Jeff.
05-17-2006, 03:34 PM | #11 |
Back in the sticks
Re: TPi
Oops, sorry the ECM is $110 and the Chip is $125, so $235 for ECM. The one you are talking about he sells for $795. Good luck, Jeff.
05-17-2006, 05:17 PM | #12 |
Re: TPi
I used a painless harness and it was truely................Painless. You'll love it once it's done.
As stated earlier................make sure you have a FULL 12 Volt supply to the computer, not just a ignition hot wire.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
05-17-2006, 11:57 PM | #13 |
Re: TPi
I beleive you can buy a commander 950 ecm/harness from holley for less then a grand. They have alot of pre-programmed setups and you can customize it yourself with a laptop.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop 70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress |
05-18-2006, 01:35 AM | #14 |
Professional Grade
Re: TPi
You have a PM
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
05-18-2006, 09:49 PM | #15 |
Keep On Truckin'
Re: TPi
You will very likely need a chip burned for your application. The '90 and later setups that are speed density, like yours, are very picky about the motor specs being quite close to what was stock. The stroker motor likely puts you far enough out that a stock chip will not work properly.
I went with Painless harness; '87 Z-28 TPI and stock GM chip. I think I'm going to have a custom chip burned given that I only get about 13mpg. Fixin' to change gears from 3.08's to 3.73's with the 700R4 which everyone tells me will help gas mileage.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
05-18-2006, 10:02 PM | #16 |
Re: TPi
mocwon, now that's a thang of beauty. Rams horns look great!
What I have a hard time understanding is why aftermarket harnesses would be better than a stock harness that has been maintained and removed properly.
05-18-2006, 10:15 PM | #17 | |
Keep On Truckin'
Re: TPi
Stock is fine if you can find one that's in great shape; I didn't have that choice since the one that was on the parts car I bought was mangled. I'd take the tape off and hunt for nicks and such and perhaps ohm it out.
