The 1ton Eaton dually axles are HO-110's correct? Ok, they have the pinion load bolt sticking out the front drivers side of the diff case just like the HO-72's used in 3/4 tons. My question is can you swap a HO-72 center for a HO-110 center? Are the axle shafts the same 19 coarse spline shafts?
72 C30 Trailer Queen
Re: Eaton dually Question
H110 have 10 wheel studs, and a non-removable rear cover (welded).
H072 have 8 wheel studs, and came in single or dual wheel configurations (1 ton). H052 have 8 wheel studs, and came in single wheel only (3/4 ton). The H110 has a much larger ring gear, so I dont know the the center section will interchange with the H072? The H052 and H072 center sections will interchange with each other, load bolt or not, dually or single wheel.
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts Last edited by Chris H; 05-17-2006 at 03:38 PM. |
OK, then I have a HO-72 under this C-30 I'm parting out, not a HO-110.... my mistake.
Thanks for the info. Last edited by Americanrider; 05-17-2006 at 01:31 PM. |
its all about the +6 inches
Chris, the HO52 was a 3/4 ton only, and the HO72 was a one ton only piece.
#5 | |
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
