Old 07-31-2002, 01:00 PM   #1
DMAN
Question transmission question
My th350 goes into gear with a hard " clunk " whenever I shift into gear from a standstill. What's the most common reason for this problem? I'd kinda like to have an idea before I take it to a shop. It shifts fine between 1st, 2nd and 3rd. Any ideas? thanks.
'71 Custom Deluxe K10, shortbed, fleetside.
DMAN is offline   Reply With Quote
Old 07-31-2002, 01:13 PM   #2
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
My first thought is the u-joints are about to go on you. Check them out for slack.
Ben
67Fleetsidedream is offline   Reply With Quote
Old 07-31-2002, 10:02 PM   #3
68 with 350 TPI
68 with 350 TPI's Avatar
I agree that it is probably the U joints.
Always replace both at the same time.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 07-31-2002, 10:09 PM   #4
Scott70Chevy
Scott70Chevy's Avatar
I agree on the u-joints, but might want to check the carrier bearing while your under there (if you have a 2-piece driveshaft).
Scott70Chevy
'70 CST: LWB, Fleetside, black ext., black/gray int., 350-4bbl, 3-speed, 12 bolt 3.07, deep dish rallye wheels, NO RUST!
Scott70Chevy is offline   Reply With Quote
Old 07-31-2002, 10:37 PM   #5
dion
72 Cheyenne
dion's Avatar
Mine does the same thing
U Joints and carrier bearing.
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 08-02-2002, 01:02 PM   #6
DMAN
thanks to all.
Old 08-02-2002, 05:33 PM   #7
COBALT
COBALT's Avatar
Not always. Check the end play of your output shaft on your transmission. Disconnect the driveline from the differential, and twist the slip-yoke to see if it rotates at all. It shouldn't; either with the truck running or off. The play may be in the transmission.
Mine clunks like that because of the detriot locker in my differential carrier. It was actually worse AFTER I got new U-joints. The reason was because the U-joints weren't loose any more, so all of the "play" was in the differential. Sometimes it clunks a bit pulling away from stops, or decelerating. It really does it after I've turned a corner, because the inside wheel hasn't engaged yet. I got so worried about it I took it back to the shop (reliable) that did the work on the axle and they just laughed. They said they get that kind of scared look that I had on my face all the time. They told me to get used to the sensation of my diff. making that noise.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 08-02-2002, 05:38 PM   #8
COBALT
COBALT's Avatar
Oh, one more thing. The "carrier bearing", or center support bearing won't make much of a "clunk" unless it's either pulled loose from the frame, worn through all of the rubber in the housing, or simply broke in two. If that were the case you'd hear rubbing 24/7 that would make you think your truck is breaking apart.
General rule of thumb is to replace the support bearing whenever you have the driveline out of the truck. If it's the in-line "I" beam type (vs. the larger "U" shaped one) don't put those dust shields back in after replacing it. Trust me they're not worth it.
I'm gonna go with a 1-piece some day. Yee-haw.
Good luck.
Seattle, WA.
