Old 05-17-2006, 02:05 PM   #1
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
Converting to a manual trans steering column w/a floor shifted automatic
i want to add a b&m floor shift in my truck and swap out the auto steering column for a manual one.i dont care if its tilt or not as a tach will be mounted on the column.my questions go as follows
to switch over from auto to manual will i have to use a manual trans truck neutral safety switch or can i use the one from the auto?
in terms of the column swap and the auto linkage which bolts to the column do i have to use manual trans linkage parts with an automatic or the ones from the auto trans?
how exactly does the shift linkage hook up on a B&M truck shifter.
thanks in advance for the replies
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
Old 05-17-2006, 08:55 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Converting to a manual trans steering column w/a floor shifted automatic
The B&M shifter will have a switch on it to do the Neutral Safety function, as well as the back-up lights. I have done three trucks this way. I put the B&M Truck Megashifter in an 84, an 86 and a 91 Chevy truck. The 84 has a "Manual Shift" column in it now and the other trucks have just had the shift linkage blocked so they don't move the lock mechanism from the "PARK" position. I did this so I could get good firm positive shifts and not slip- into reverse by accident.
The column shift parts are in my storage pile, the B&M shifter has a cable that replaces all of that stuff.
piecesparts is offline   Reply With Quote
Old 05-18-2006, 07:11 PM   #3
1974ChevyC10
so this cable does it hook to the linkage piece on the side of a turbo 350 or is that piece replaced too.how hard is it to wire up the neutral safety switch that comes with the B&M megashifter and the back up lights as well.the megashifter has i believe its called a reverse lockout on it(the little handle you have to grab and pull it up when you select a gear to shift into keeps from knocking the shifter into another gear while in motion) is that correct.how hard is it to install the shift cable on it as well.
Red-1978 C10 LWB
Old 05-18-2006, 07:35 PM   #4
piecesparts
I could tell you all of the neat things and such, but I am enclosing a link to the B&M Megashifter PDF file for installation. http://www.bmracing.com/media/products/pdf/10.pdf
The cable is easy, the company sends the brackets necessary along with pictures. The wiring is easy also---just connect the shifter to the wiring that is on the switch on top of the column up under the dash for the Neutral Safety switch. The back up lights are also easy, you will have to find those wires on the switch on the column too.
