Old 07-31-2002, 01:14 PM   #1
Michael A. K. G
Manual tranny interchange possible?
Hi folks.
I have a recently acquired '72 C-10 with a 3speed manual (Muncie, I think) and a column shift, behind a 250cid inline six. It has the integral low hump.
Is it feasible to replace this with a 4speed and regear with a lower (numerical) ratio in the diff, to approximate an overdrive? I know I'll have to cut a hole in the floor for the stick; my main question is, what about driveshafts and clearance. The one four speed I found in the junkyard was much more "boxy" than the 3speed I currently have; it has no tailshaft housing (and it was in a Chevy Van). Will it clear the low hump? Are there driveshaft issues?
This particular 4speed was also behind a 250cid inline six, but can I take a 4speed from behind a small block V8 instead? Or should I just take the small block with it (big sale on engines at this junkyard -- $70 including accessories and flywheel, assuming you can find one in one piece)? What would be a good displacement for mostly highway/mountain driving and light hauling (I don't need massive power, just decent, and ok gas mileage would be a plus).
TIA.
Michael A. K. G is offline   Reply With Quote
Old 07-31-2002, 05:05 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Being that you have an inline 6 in your ride, I think I would look for a T-5 tranny out of a camaro. It will hold up to your motor, and you'll still have your pullin power, and an overdrive for the freeway.
Old 07-31-2002, 05:55 PM   #3
Michael A. K. G
Well, that sure does sound simpler.
T-5s were used in Mustangs, too, weren't they? Different bellhousing?
I presume it's a different length than stock, so a custom driveshaft would be needed, right? Is it longer or shorter?
And I presume I still have to cut a hole in the floor. Or was there a column shift Camaro (or would that be just stupid in a sports car)?
Hey, thanks.
Old 07-31-2002, 05:57 PM   #4
Longhorn Man
Mustang...don't even try it. If memory serves, it's more troule than it's worth.
The S-10s had it too, but it was weaker.
Yes, a hole in the floor, plus, fabbing a shifter that would not come up inder the seat maybe(not sure bout that)
Old 07-31-2002, 06:16 PM   #5
Michael A. K. G
Correct me if I'm wrong, but wouldn't the tranny have to be outrageously long (and have a far-back shifter) to come out in the seat in this truck?
If memory serves me right, the clutch is more or less right at the firewall.
Fabbing a shifter is not something I'm sure I can do. I've never done it before. Are there adapter kits or do I get to spend big bucks having one fabbed by a machine shop?
Or do I just get one from an S10, since that already IS a truck? Can the guts be interchanged (I do have a press, splitter, and a homemade long-reach bearing puller, if needed)?
By "weaker" do you mean it breaks more easily, or has worse gear ratios?
