Old 05-17-2006, 11:08 PM   #1
Medicanman71
Medicanman71's Avatar
Question Drilling holes through my frame
Going to be putting tow hooks on the blazer , what's the best way to go about drilling the holes? Only have to do one hole on each side since the existing hole on each is already present. Do i just get the proper bit ,and go to town on it, or what? Any words of wisdom? (yes i'll be welding the nuts)
Thanks guys!
Medicanman71 is offline   Reply With Quote
Old 05-17-2006, 11:23 PM   #2
Shane
Shane's Avatar
Re: Drilling holes through my frame
use center punch, center drill, pilot drill and then the finish size drill ... a pilot drill is HALF the size of the finish drill ... in other words, if you need a 3/4" hole as a finish hole, pilot drill it at 3/8"
Shane is offline   Reply With Quote
Old 05-17-2006, 11:24 PM   #3
roj2323
use a small bit "1/8in" and drill the center points. then go ahead and drill with the larger bit or a unibit. i mentioned the unibit because it will litteraly drill to the size hole you want 2-3 times faster than a standard bit and there garenteed for life. they are a little expencive but it's well worth it to never have to buy another bit again.
ondrew
roj2323 is offline   Reply With Quote
Old 05-17-2006, 11:43 PM   #4
Medicanman71
This is excellent info, thanks so much for the help. I figured i'd use a center punch. I didnt think of using a bit 1/2 the size of the hole i'll need though, then finisng with a bit(or unibit, i'll look into this) that's the size of the hole i'll finally need. Thanks so much for clueing me in guys.
Old 05-18-2006, 11:29 AM   #5
dennislbrooks
dennislbrooks's Avatar
any particular brand of unibit you like? or is there only one brand?
dennislbrooks is offline   Reply With Quote
Old 05-18-2006, 01:07 PM   #6
67sub
67sub's Avatar
I used a unibit brand and it went through the frame like a hot knife through butter, literally less than 30 seconds per hole. Center punch it and go with the unibit. Done it several times.
2004 Kawasaki KLR
Always looking for a cheap driver
67sub is offline   Reply With Quote
Old 05-18-2006, 02:06 PM   #7
Orange
Licensed to Thrill!
Orange's Avatar
On tough metals I always use some Tri-Flow (expensive WD-40) to help with the cutting. Same principle machinist use with cutting oils.
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
