Old 05-18-2006, 09:08 PM   #1
mike in mo
1950 GMC wants a V8
hey guys has anyone done this? i want to put a small block in my 1950 GMC but i want to keep it looking stock and use the stock 4 speed tranny i know i got to put a chevy x member in for the rear motor mounts to bolt to but i dont know what to do about the cluch and brake pedal where it drop under the floor? i think i can overcome the rest of it but just dont know what to do about the clutch and brake.
thanks for any and all help
Mike in Mo
mike in mo is offline   Reply With Quote
Old 05-20-2006, 11:02 PM   #2
Apache
Apache's Avatar
Re: 1950 GMC wants a V8
Ive never tried putting a V8 in a 47-55 (first series) so I cant really help with your pedel question. Just wanted to let you know Ive heard that you will run into a problem with the steering (tight fit). Again, I dont know for sure but something worth looking into.
54 Chevy Bel Air 4dr powerglide
54 Chevy SWB
58 Chevy Big Window SWB Fleetside project
58 Chevy LWB 235/4spd
76 Chevy Nova 350/TH350 4.88's *10kmiles on "new" engine
79 Chevy 4x4 SWB 350/4spd 3/4 ton
81 Mazda RX7
84 F@!d Mustang
96 F@!d Ranger 2.3L/5spd
Apache is offline   Reply With Quote
Old 05-22-2006, 11:48 PM   #3
mike in mo
yea the steering box has to move over about a inch but thats not a big thing.
Old 05-23-2006, 04:47 PM   #4
53 Chevy
You can use the pedals you have now. i have seen a few that used the original pedals and i have seen some with hanging pedals which is what i have on my 53. but it is an automatic.
53 Chevy is offline   Reply With Quote
Old 05-30-2006, 10:59 AM   #5
solidaxel
solidaxel's Avatar
I used a truck bellhousing for a V8 and all of the stock linkage and throwout bearing clutch fork and a NEW tremac 5-speed, I used the stock crossmember with the bellhousing mounts, works great! I did have to shorten the driveshaft a bit as the 5 speed is a bit longer
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
