05-18-2006, 10:48 PM | #1 |
Rear Cab Moulding ?
My 77 Bonanza does not have the Cab moulding since it is a sloid Mariner Blue truck and it was an option that most Bonanzas dont have . I bought a couple complete GM mouldings and want to install one on my truck . Is it something best taken to a body shop or does someone have a link to how to properly install one ? I need the measurements for the holes on the sides for sure . Would it be best to have the little T studs (welded on ) installed or is there another way to install the rear section ? Frank
Born and proudly residing in a Red State ! |
05-22-2006, 10:52 PM | #2 |
Re: Rear Cab Moulding ?
Anyone ?
05-23-2006, 07:18 AM | #3 |
Active Member
Just a thought, but have you posted this in the paint/body section? That's where the folks who live and breathe this stuff hang out
And no, I'm not one of them and don't have the answer Brian |
05-23-2006, 08:11 AM | #4 |
The proper way would be to weld the studs onto the body, then add your clips and trim. I have heard of folks using sheetmetal screws (and clear RTV to seal them) to hold the clips on.
05-23-2006, 10:59 AM | #5 |
The corner mouldings fit with a bolt thru spring clip. And the rear cab moulding is a screw thru nylon clip. A trip to the local boneyard with a flat and phillips screwdriver a 3/8 & 5/16 socket and a tape measure would get you the clips and mounting dimensions.
Here's a cut of what you need. Caution: The corner mouldings require a reach up behind the seat into the "B" column to access the nut on the spring clip. Good luck and send pics when done. - Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
