Old 05-19-2006, 12:50 AM   #1
powell72
powell72's Avatar
1970 half ton coil spring frame cheap
I need to get rid of this frame since I'm dragging more stuff home by the day. It is only the frame with crossmembers. Someone spend an entire Saturday welding a bumper onto it instead of just drilling some holes. It has small block stands and an auto crossmember. This is a straight frame no damage, I parted this truck out. $50 you pick up.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 05-21-2006, 02:27 PM   #2
powell72
powell72's Avatar
Re: 1970 half ton coil spring frame cheap
ttt, anyone? offers? trades? I gotta get this thing outta here.
Chris
Old 05-21-2006, 02:32 PM   #3
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
This is a good one to shorten and install all the cool custom air ride stuff on while you drive your truck til it's ready to swap. if I was closer that baby would be in my garage. Wish I was closer.
Oldtruckfanatic is offline   Reply With Quote
Old 05-22-2006, 09:00 PM   #4
silvertonguedevil
silvertonguedevil's Avatar
Have a torch? And willing to part it out further? I need the center section of the cross member that the driveline passes through. I only need the center section so I would need it cut on the outside of where the rear trailing arms bolt up. I could also use the front cross member. Any idea on shipping to 97006?
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 05-22-2006, 11:40 PM   #5
powell72
powell72's Avatar
I'm gonna let it ride a little longer and then I'll get back to you.
Chris
Old 05-23-2006, 01:11 AM   #6
silvertonguedevil
Sounds good. Just let me know.
-Greg
1974 C20 Cheyenne
Old 05-25-2006, 01:03 AM   #7
powell72
powell72's Avatar
Last ttt......
Chris
