Old 05-19-2006, 12:18 PM   #1
AWEGS72
AWEGS72's Avatar
Got flames? as in flame kits for exhaust
Anybody in here put flame kits in their exhaust?
AWEGS72 is offline   Reply With Quote
Old 05-19-2006, 02:06 PM   #2
motocrosschump
Re: Got flames? as in flame kits for exhaust
isn't a matter of inserting a spark plug in your exhaust and splitting a plug wire to it?
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 05-19-2006, 02:07 PM   #3
Lemield
Lemield's Avatar
I do.
It's a spitfire kit and it was easy to install. Shoots about a 3 ft flame when the exhaust is good and hot. Seems to discourage tailgaters.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 05-19-2006, 03:03 PM   #4
AWEGS72
AWEGS72's Avatar
LEMIELD:
Do you have to run your system rich in order to get enough burnable fumes to ignite? I was on www.hotlicksexhaust.com and they have a system I was looking into. A friend of mine did a propane flame kit on his which burns blue,but its all fabricated.
Old 05-19-2006, 03:23 PM   #5
Lemield
Lemield's Avatar
LEMIELD:
The kit that I have works by interrupting the ignition system and sending a pulsed spark to two spark plugs in the tail pipes. Press the button and pump the accelerator a couple of times and the raw fuel is atomized and is sent out to the exhaust pipes, ignited and voila...flames.
It does wash down the cylinder walls and probably dilutes the oil to some extent so I change my oil at a shorter interval. It's not good for the engine but I don't do it all the time so I'm willing to accept the risk. It sure does look cool at night on a dark street!
http://www.hotrodsetc.net/orderspitfire.htm
Larry
Old 07-03-2006, 11:03 PM   #6
TugOwar
More info on this would be nice. Is there not enough burnable gases in the exhaust to ignite? Why couldn't you just mount spark plugs in the tail pipes and run a toggled 12 volts to them?
TugOwar is offline   Reply With Quote
Old 07-03-2006, 11:14 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if your carb is adjusted right, then there won't be nearly enough fumes to ignite. I have seen ppl who had wired up a coil and spark plugs in there tail pipes,a nd then pulled the manual choke and toss the toggle, but I can't say how it would comapir to a real system.
I'd like to see it on side pipes personally.
www.mooneyes.com has a flame thrower kit too.
Old 07-04-2006, 02:51 AM   #8
MisterMan
MisterMan's Avatar
the fuel is long sense burnt. thats why the system "retards" the ignition so the engine dosent burn it, it just lets fuel get blown down the exhaust system, the plugs then ignite the mixture... it looks cool, but does nothing but "wow" ppl.
I would splash some methonal on my tips before i bought a systm. hahah
MisterMan is offline   Reply With Quote
Old 07-04-2006, 06:16 AM   #9
toddtheodd
The oddest Todd around
toddtheodd's Avatar
A good system would be to use an injector run off of a washer motor to inject gas into the pipes about 12 inches in front of the spark plug. That way you don't hurt the motor doing it.
Also, this way you can flip the switch and slap the peddle to the firewall so that it's a triple dose of flames, being loud, and burning tires.
Toad
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 07-04-2006, 08:35 AM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Looks killer when done right
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-04-2006, 09:17 AM   #11
mbgmike
I think its silly but then thats just my opinion
mbgmike is offline   Reply With Quote
Old 07-04-2006, 01:49 PM   #12
wibilly
wibilly's Avatar
i like the idea of melting the plastic bumper off tha little red car on my a$$ as i head down the highway turning 3500
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 07-04-2006, 03:25 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by toddtheodd
A good system would be to use an injector run off of a washer motor to inject gas into the pipes about 12 inches in front of the spark plug. That way you don't hurt the motor doing it......
Your kidding aren't you? First the washer pump would be destroyed by the gasoline, then the vehicle that it's installed in would be destroyed by the ensuing fire.....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-04-2006, 04:20 PM   #14
TugOwar
LMAO! Yeppers!
I just like the idea of blowing peoples minds. Its a totally impractical and useless mod but the cool factor would be priceless!
Old 07-04-2006, 10:01 PM   #15
TravisH
TravisH's Avatar
Any more info on this? I'm assuming he'd use one of the mini bottles but whats hes using to inject it?
TravisH is offline   Reply With Quote
Old 07-04-2006, 10:16 PM   #16
mbgmike
We sell em if you want to buy em. If that floats yo boat. I don't think it really blows peoples minds. the options are endless on what you can do. You can rig up just about any gas. I still think its silly. spend your money on better things than Blowing someones mind. If I had a rat rod my look cool
Old 07-04-2006, 11:40 PM   #17
chevybill
chevybill's Avatar
Flaming exhaust is straight out of the fifties, just like baby moon hub caps, souped up flat heads and fender skirts. A classic 50's touch to car culture.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 07-05-2006, 07:28 AM   #18
70c10
67-72 Addict!
70c10's Avatar
I think flame throwers are cool looking at night but knowing me I would burn something/someone down,lol.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-05-2006, 10:19 AM   #19
Lemield
Lemield's Avatar
I agree.....flame throwers are silly. But I only have about $100 bucks invested in mine and that's a cheap price for all the entertainment value it has provided.
Larry
