Still Green but learning
AC Clutch GAP?
what is the proper gap between the AC Clutch and the comressor assembly. I have a puller installer and the part, I am ready to go and want to get it right.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
Re: AC Clutch GAP?
oops,
factory (or replaced) frigidaire A6 compressor on a 71 C10 2wd,
Re: AC Clutch GAP?
Googled the answer to my own question, .030" does that sound right to you guys.
![]() Join Date: Aug 2004
Re: AC Clutch GAP?
.030 Sounds good. You'll know if it's too much, the clutch will slip. If you have a few varied sizes of shim washers it should be easy to adjust.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
