05-19-2006, 12:59 PM | #1 |
JamesChurch13
Static Drop
What is the Lowest Semi Street Friendly Drop? I got a 67 swb and am moving to vegas in like 3 months once i return from Japan from the airfoce. So far i got 5 inch drop springs for the rear. What else should i get for the meanest static drop possible.
HG/FTW!!! Current vehicle collection: 1968 Chevy C-10 SWB Fleet Side, 327ci, TH350 (MD) 1987 Chevy Dually Quad Cab, 427ci, TH400 2008 Buell XB12SS, 1203cc 2006 YZ450F Wheelie Machine! 1997 Suzuki Bandit 600cc And the Wife has some cars I pay insurance on and use to transport the kids!(01' Grand Cherokee and 06' Pontiac Grand Prix) |
05-19-2006, 06:28 PM | #2 |
Re: Static Drop
you could do a 2.5'' spindle, 2'' spring in the front and a 1'' block to go with your 5'' spring. Don't forget your shocks relocator mounts, and adjustable panhard. You could go lower than that, but that setup is pretty street friendly.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
05-19-2006, 06:40 PM | #3 |
Re: Static Drop
Here is a pic of my sons old truck. 6 inch drop springs and 2 inch blocks in the rear and 2 1/2 spindles and 1 coil (2-3 inch)cut on the front springs Since it was a long bed I thought it would have problems but you just had to be careful
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
05-19-2006, 11:55 PM | #4 | |
JamesChurch13
Re: Static Drop
05-20-2006, 10:02 AM | #5 |
Re: Static Drop
A 4" front and 6" rear would be a safe daily driver. I would not go any lower on a spring drop for a DD I drive mine daily over 6000 miles with it finished and only 1 time have I dragged the front lower A arms when pulling into a really steep incline.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
05-20-2006, 01:34 PM | #6 |
JamesChurch13
Re: Static Drop
How is your truck droped and what parts did you use? Thanks. What do you guys think of a 6/8 static? I Want the look and the price is right. Trouble vs Looks. What to do?
HG/FTW!!! Current vehicle collection: 1968 Chevy C-10 SWB Fleet Side, 327ci, TH350 (MD) 1987 Chevy Dually Quad Cab, 427ci, TH400 2008 Buell XB12SS, 1203cc 2006 YZ450F Wheelie Machine! 1997 Suzuki Bandit 600cc And the Wife has some cars I pay insurance on and use to transport the kids!(01' Grand Cherokee and 06' Pontiac Grand Prix) Last edited by JAMESCHURCH13; 05-20-2006 at 01:37 PM. |
05-20-2006, 08:18 PM | #7 | ||
A guy with a truck
Re: Static Drop
If you like the look of 72blazerdude's truck, do that. If you don't, you'll be mad at yourself for not going lower. Are you really dropping the truck because you wnt to be conservative? Didn't think so... Front: Spindles- $200 Cut Coils- Free Alignment- $60? You will also want to move the sway bar mounts up to the frame, eliminating the low hanging brackets. Rear Springs- $60 Blocks- $60 Notch- $150 Shocks all the way around- $100 I would definitely recommend relocating rear shock mounts too... Cheap AND looooow. I say gopher it!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 05-20-2006 at 08:26 PM. |
05-21-2006, 04:00 AM | #8 | |
JamesChurch13
Re: Static Drop
05-21-2006, 12:01 PM | #9 | |
Re: Static Drop
If your statement of "loose to coils" means removing 2 coils from the front springs, that's a bit too much. Any time the front suspension is 'unloaded', the front springs are short enough they can become dislodged. This can happen when jacking the truck up in the driveway (or putting it on a lift), which is no big deal. It can also happen on a big enough crest on a highway, which is a very big deal. The other problem w/cutting 2-coils is the spring rate isn't increased enough to compensate for the now much lower heights resulting in poor quality ride vs. the amount of suspension travel. If you want over 2~3" of drop from the springs only, buy aftermarket drop springs that are engineered for the task. Use the spindle + spring combo. Don't go as radical; or don't do anything until you can do it right. This is just opinion from someone who has ridden in vehicles done both ways so it can be taken for what it's worth.
05-21-2006, 12:12 PM | #10 | |
JamesChurch13
Re: Static Drop
05-21-2006, 02:06 PM | #11 |
JamesChurch13
Re: Static Drop
Very Rough Sketch... Never mind the sketch its too big a file. Hmmm... Well its like this... Weld in two thick strong plates. One to the bottom A arm and the other to the top spring pearch. Drill holes centered over spring location size of large i-bolt treads. I bolts would be welded shut once heavy gauge chain is inserted. So you would have a heavy duty chain maybe 4 or 5 links long and an I-bolt at each end. Top I-bolt would be put through spring pearch once whole assembly was inside of spring with one coil removed. This I-bolt would be secured with a large thick washer and two nuts that lock against each other and dont interfere with upper A arm. Next the bottom I-Bolt would be put through the bottom A arm same as the upper spring pearch. Now the difference is this one would be tightened to desired hight to create drop. Then once height was deemed good second lock nut would be placed on assembly. End result low truck with stiff ride and no possibilty of spring dislocation. Will this work. I think it will and am willing to try it. However as a disclaimer... Im sure this is not legal and I should not be held responsible if some one else trys this and it does not work. That being said if some one does or has tried such a contraption let me know how it works or worked. I'm in Japan and will not be home till August. I would try it on my twin turbo charged Subaru Legacy GT but its low enough all ready. Plus its got Shock struts.
And Before someone gets all upity I already Know! Ol Skool and Cheap are synonimous. Peace.
HG/FTW!!! Current vehicle collection: 1968 Chevy C-10 SWB Fleet Side, 327ci, TH350 (MD) 1987 Chevy Dually Quad Cab, 427ci, TH400 2008 Buell XB12SS, 1203cc 2006 YZ450F Wheelie Machine! 1997 Suzuki Bandit 600cc And the Wife has some cars I pay insurance on and use to transport the kids!(01' Grand Cherokee and 06' Pontiac Grand Prix) Last edited by JAMESCHURCH13; 05-21-2006 at 02:07 PM. |
05-21-2006, 03:32 PM | #12 | |
Re: Static Drop
I'm not an engineer, but intentionally compressing (or limiting) the suspension travel w/chains sounds unsafe. It sounds like you don't have the means to do this correctly so I encourage you to just wait. Everyone's safety, yours & those on the road around you, is far more important than looking cool. If you can fabricate a couple of plates for your idea, do some side fabricating for enough $$ & install 2-airbags w/schrader valves. 2-bags should only be about ~$150.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-21-2006 at 03:33 PM. |
05-21-2006, 03:56 PM | #13 | |
Señor Member
Re: Static Drop
05-21-2006, 09:08 PM | #14 |
Epoxy Primer Friendly
Re: Static Drop
thats sounds like a ghetto weightjack setup like used in OVAL TRACK cars.. Just manual bag it, with ball valves.
05-22-2006, 12:14 AM | #15 | |
JamesChurch13
Re: Static Drop
05-22-2006, 12:32 AM | #16 |
JamesChurch13
Re: Static Drop
By the way my end goal for my 67 Swb is to have here ride on full bags and sit frame. However about a year and a half ago I got a v8 350 to replace the more than worn out Inline 6 and with it I bought all the normal stuff. Edlebrock pro intake, Accel distributer cap ect., and the thing that will undoubtible f@#$ me over long tube headers from headman. I also got a set of puple hornies that are 33inchs long and end the exaust turned down about 3 inchs behind the cab. If this manual bags works a nice as it should i'll be getting manifolds or shorties and running the exaust tucked up next to the frame. And why change my project in the middle of my build you ask? Well its simple. I surf and get tattoos and listen to punk. Being over seas for 3 years and some odd months Ive never seen a C-10 in real life dropped on bags. I thought only import wanna be S-10s with neon pink paint did that. A couple jokes in that last sentence. Ha Ha. But dude Sitting frame on these C-10s looks bad A$$. I'm saying that is hottness. C-Thunder, XXL, And the dude with the Blue C-10 that just got doored whos name I cant rember right now you guys got the coolest trucks IMHO Ive ever seen PERIOD. To add to that I saw a video of a 73-80 C-10 Draging down some random road and that is just to cool. Sparks at night in most exellent truck equalls greatness. Well I'm out for now. Thanks one more time and any pics or tips would be way cool. Peace.
05-23-2006, 12:03 AM | #17 |
Re: Static Drop
Dang..... slow down man you're makin' me dizzy.
Yes, bags can be installed & used w/o a tank or compressor. The drawback is if you don't carry a portable air tank, you can only adjust ride height @ a gas station that has working air (no really, some gas stations actually have air that works....). Also, a portable air tank won't do much for you . . .... but it can work in a pinch. Yes, bags installed this way use schrader valves to inflate. The schrader valves can be mounted in an accessible, convenient place w/the air line routed to the bag. The problem lies in accurate air measurement @ alignment height. If you use a typical tire pressure guage for verifying the air psi, results may vary which will affect the alignment. I know of one guy that used to post on here that made a 'jig' that he slid under the truck to make sure he was @ his alignment height. I don't know how accurate that method was for him but it sounds like it could be made to work w/a little creative thinking (of which you seem to have a firm grasp!). The rear drop @ ride height using bags & 2" blocks would be about 6~7" drop. That would definitely benefit from relocating the shocks, adding c-notches, & re-centering the rear either by cutting the original panhard bar to the proper length or getting an adjustable one. The front drop @ ride height w/bags only is prob around 3" drop so that's still not in the realm of what you're looking for but is safer if done correctly. You could try 'stepping' the lower a-arms 1~2" @ the ball-joint area. This would have a similar affect as a drop spindle w/o having to swap to discs because you retain your stock spindles. This combined w/front bags would get you on down. There was an article in Streettrucks magazine a few years ago on this subject & @ one time the guy that wrote the article built these arms (he's no longer doing business). Search for "The Big Low Down" Streettrucks mag January 2000 (issue # 4 ) to get educated on the subject. If you consider doing this mod, please, please have a certified welder do the work. This is no time to be practicing your welding skills. The a-arms would need to be properly cut & then boxed for reinforcement & you will be limited on your wheel backspacing.
05-23-2006, 12:26 AM | #18 |
Re: Static Drop
Here's what stepped arms look like. These pics are from slightly different angles showing the gussets . . .....
05-23-2006, 02:59 PM | #19 |
JamesChurch13
Re: Static Drop
Who sells those or you gotta have them made? Thanks Scotie for all the help your exellent.
05-23-2006, 03:09 PM | #20 |
Re: Static Drop
James, I'd stay away from a 3" block in the rear, your shock mounts will hang below the scrubline if your tire goes flat it's metal on pavement...
2" blocks should be fine... Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
05-23-2006, 03:30 PM | #21 | |
JamesChurch13
Re: Static Drop
05-23-2006, 03:54 PM | #22 | |
Re: Static Drop
The guy that was selling them is no longer in business as far as I know. Several board members here had issues w/his products and/or customer service. My neighbor that bought the ones in the pics had a hard time getting his 'core deposit' back after returning his old arms to them. They also didn't send him all the sway-bar stuff that he paid for. I felt bad because I'm the one that suggested the guy (Turner Enterprises).
I will say the arms were quality built & worked on his 66. You can see in those pics the other stuff I used: 2" blocks, new gas shocks, & he already had some drop springs. Quote:
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-23-2006 at 03:55 PM. |
05-24-2006, 04:52 PM | #23 |
JamesChurch13
Re: Static Drop
That sounds like a good idea.[/QUOTE]
Thanks man some times I get a good idea. It's hard to not get balls deep into somthing then be like oh wait thats silly I should have waited. Thanks to all the board members for all the help on this. I've got 3inch front and 5inch rear drop springs on the way from Gmc Pauls and toxic drop shocks from summit. Should I get my Panhard bar shortend or buy the adjustible one?
HG/FTW!!! Current vehicle collection: 1968 Chevy C-10 SWB Fleet Side, 327ci, TH350 (MD) 1987 Chevy Dually Quad Cab, 427ci, TH400 2008 Buell XB12SS, 1203cc 2006 YZ450F Wheelie Machine! 1997 Suzuki Bandit 600cc And the Wife has some cars I pay insurance on and use to transport the kids!(01' Grand Cherokee and 06' Pontiac Grand Prix) Last edited by JAMESCHURCH13; 05-24-2006 at 10:16 PM. |
05-24-2006, 10:18 PM | #24 |
Re: Static Drop
I shortened one for my 67 years ago & I used an adjustable one on my 68. The adjustable bar was fairly straight forward & was easier since you didn't have to worry about the exact length w/the ability to adjust.
That would also allow you to re-use it later on when you do get around to bagging it.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-24-2006 at 10:19 PM. |
05-25-2006, 03:08 AM | #25 | |
JamesChurch13
Re: Static Drop
