An American Soldier
![]() Join Date: Feb 2005
Troubleshootiong Gas Gauge????
Okay, my gas gauge stays at Empty...maybe 1/4
here is what I did today... pulled the sending ubit...with float lowered it measures 1ohm and with float raised, it measures 90ohms The float floats The wire from the sending unit to the fuse box ohms out good What next???? Thanks,
Dan dan.brue@us.army.mil |
Gone Fishing
Re: Troubleshootiong Gas Gauge????
sounds like the resistor try
http://www.fix-a-gauge.com/
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
An American Soldier
Okay, i just read my post. Yes, my gas gauge stays between Empty and 1/4, but it does actually have gas (expensive gas) in the tank.
#4 | |||
Union Electrician
I agree with jsb and I think if the gauge itself is good, can try by grounding out the sending unit wire and it will go past empty(shorted out), or unplug the wire and it should go past full(open circuit)
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
An American Soldier
There was not even a wire hooked up and the needle stays at just over EMPTY. I think the gauge is bad.
its all about the +6 inches
Pull the insterment panel, and make sure that the printed circuit is still good. I've seen more of them damaged that actual bad guages.
