Old 05-19-2006, 03:46 PM   #1
bagged91
Out draggin'
bagged91's Avatar
factory a/c setup 4 sale
67-72 pickup factory A/C system(from a 72). Comes with everything that attached to firewall including vac. vents controls & harness. No lines, motor brackets or anything that bolted to core support. No ball housings or center vent... $200 obo
I would prefer local pickup as it is big, bulky & fragile & I don't have anyway to post a pic to show you what your getting... I will not seperate.
Thanks!
Joe
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 05-20-2006, 04:31 PM   #2
webbes
Re: factory a/c setup 4 sale
any pictures
webbes is offline   Reply With Quote
Old 05-22-2006, 03:52 PM   #3
bagged91
Out draggin'
bagged91's Avatar
Originally Posted by bagged91
I don't have anyway to post a pic to show you what your getting... Thanks!
Joe
No Camera, no way to upload either. Using the library's computer...
92 GMC K1500 Burb
Old 05-24-2006, 03:33 PM   #4
bagged91
Out draggin'
bagged91's Avatar
bump...
92 GMC K1500 Burb
Old 05-30-2006, 03:44 PM   #5
bagged91
Out draggin'
bagged91's Avatar
Boy its hot out...
92 GMC K1500 Burb
Old 05-30-2006, 06:43 PM   #6
makovai
makovai's Avatar
Boy its hot out...
it sure is, but i need everything. The only thing left on my rig is the vents.
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 05-31-2006, 03:26 PM   #7
bagged91
Out draggin'
bagged91's Avatar
All you need for this is the lines going from the box on the firewall(which you would want new anyway), the compressor & brackets & a condensor... Everything else is there including the vaccumm lines, a/c wiring harness(uncut) and the controls. The vaccumm operated vent for the cowl & the kick panel are there also... I have the dryer but I didn't mention it because you would want to replace that when hooking up anyway...
92 GMC K1500 Burb
Old 06-06-2006, 05:12 PM   #8
bagged91
Out draggin'
bagged91's Avatar
one more time?
92 GMC K1500 Burb
