Insert Title Here
how to wire 3rd brake light
Let me just first say, I have never wired anything before..lol
so how do I go about hooking up a 3rd brake light, it is just a billet pedastal mount going inside between the seats.. Thanks for any info
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Next project: 1970 K10
Re: how to wire 3rd brake light
You can tap into the wire coming right off of the brake light switch on the brake pedal. Use a test light and find the wire that is hot when the brake is pushed. Red wire from the 3rd light to that one, black to ground.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
'68 C-20 396 CST CC
![]() Join Date: Mar 2005
I think Early Classic Enterprises has an LED light kit that replaces the original cargo-light with a third brake light. I'd have to hunt through their site but I'm I'm home on dial-up right now. WAYTOOSLOOOOWWWW!!!!
![]() The switch behind the pedal is a grounding circuit, though--I think. You wouldn't be able to just tap a hot wire there. The kit had a plugin-like setup that tapped into the orignal harness somewhere, but I think it also had LED lights for the tailights as part of the kit. I'm not a fan of LED taillights, but I'd like to see a third brake light using a standard 1157 bulb in a cargo-light. ![]()
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES ![]() 01 Jetta Turbo Daily Driver ![]() 84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico ![]() |
#4 | |
its all about the +6 inches
I don't have my schematics with me at the moment, but I'll bet a kick to teh daddy parts that that switch is on the positive side.
Cat's eye, years ago, before ECE did there conversion, I had mounted a hand full of LEDs in my cargo light, which permitted me to be able to maintain the white light function too. It was pretty badass. Why don't you like LEDs? I have NEVER seen anyone say that before. Not flaming, just curiouse. Last edited by Longhorn Man; 05-20-2006 at 05:20 AM. |
I did mine. Very easy to do. Find the wires that connect to your brake switch. One wire is 12 volts power and the other wire will send 12 volts to the brake lights when the peddle is pushed. Just tie in your 12 volt wire from your led light to that wire going to the brake lights. It doesn't matter if it's an led or regular 3rd brake light. You won't need the fancy kits to do this.
Here's a picture of mine. steve
1997 GMC Sierra Ext 1965 Mustang |
Yup, it is power, and not ground. There is an orange wire, and a white wire. I beleive it is the white wire that you will tap into. But be sure to confirm with a test light or multi-meter.
'68 C-20 396 CST CC
Andy, you're funny! Kick to the daddy parts...
![]() I don't really hate LED's I just prefer the original look. I'm not a fan of the clear lenses either, but that's just a preference. You guys are right. My bad--it is a hot wire. ![]() I think I was thinking of the wire that goes to the proportioning valve and I assumed it was the same situation at the pedal. Steve--that light looks good. ![]()
I agree with you about the original look up to a point. That's why I placed LED tail lights under my stock red (and poor condition) lenses in back, and my 3rd brake light/cargo light assembly looks totally stock and unmodified untill you hit the brakes.
The 3rd brake light pic here is with lame, weak, pansey girlie lights... They've been replaced with some kickin LEDs... still looks totally stock with the lens on. I hope to maybe install that cargo light in a week or two. |
