05-20-2006, 01:54 AM | #1 |
Windows don't roll up and down smooth
What's the deal? Something bent of out of alignment? Anyone have this problem? The crank is really hard to turn at the 6 o'clock position of the window crank. Passenger side is even worse.
Photo Gallery of 1972 K/5 Blazer CST |
05-20-2006, 01:58 AM | #2 |
SKINNY TIRES RULE!
Re: Windows don't roll up and down smooth
What is the condition of the window guides? If the felt in the tracks is in bad shape it can make it hard to roll the windows up/down.
I'd pop the door panels and loop the mechanisms up really well to see if that helps.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
05-20-2006, 02:36 AM | #3 |
JB-80 "Twice as Good"
LUBE,LUBE,AND MORE LUBE!!!!!!!!!!!!!!!
HEY NOW! |
05-20-2006, 02:50 AM | #4 |
Felt is perfect. Lubed once before. Guess I will lube again and see. I I'll try some anti sieze thread compound.
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 05-20-2006 at 02:51 AM. |
05-20-2006, 03:59 AM | #5 |
Anti seize gets a bit stiff in the winter. Molygraphite is super slick all year long. Also silicone is safe to spray down in those guides. Won't hurt the felts. Probably got lots of that desert dust in there. Make sure you get every possible friction point. If that doesn't help, it might be time for new regulators. I think they are about $40 from LMC, but might be cheaper elsewhere. Good luck!!
To go with honor and courage, a far and wonderous distance |
05-20-2006, 07:41 AM | #6 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
05-20-2006, 09:07 AM | #7 |
i have to grab the top of my window to roll it up or down. But i know all my stuff is worn out.
If it aint broke..............fix it till it is. www.fast77.com 1972 - 330 hp crate, 11" lift with 39x18 mickeys. 3/4 ton, cross steer, 4 wheel disc brakes 1996 Z71 w/ 35's |
05-20-2006, 09:08 AM | #8 |
Just a thought, sometimes in the past when I have worked on old cars rust will build up and swell at the pivot point of the regulator. Take them out and hit them with a punch and a hammer at the rivet point and they should loosen up some. Try it, it just might work for you and lube while you are in there.
05-20-2006, 10:30 AM | #9 |
If the lube and giving the pivot points a whack does not work, then I'll look at replacing the regulators. Thanks guys.
05-20-2006, 12:23 PM | #10 |
"1972 C5"
If you find the answer post it please because I have the exact same problem.
05-21-2006, 12:03 AM | #11 |
Arent you supposed to use one hand to help push/pull the window up/down when you use them?!?!?!?
But really, i just roll them down and leave them that way once it's nice Problem solved. |
05-21-2006, 09:48 AM | #12 |
I spray my window tracks with silicone spray. I converted my windows to electric and the silicone keeps them moving smooth. I use it on my other vehicles also. I have found that if you spray down the door seals it also keeps them from freezing the door closed during the winter.
05-21-2006, 11:21 AM | #13 |
Premium Level Member
I had/have same problem. Both windows were hard to roll up and down.
*For the Drivers side, I changed the regulator with an NOS one. I also changed all of the tracking and door rubber/felt. This window almost rolls itself up it is so easy. For the passenger side, I did not change the regulator, just cleaned and lubed it up with plenty of grease. I did change the tracking and door rubber/felt. Although easier to open, it is not as easy as with the new regulator. So, your best bet if you are looking for easy rolling is to change the regulators. Its is not difficult, just need to take your time.
69 K5 CST stock- 350, 4speed 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, |
05-21-2006, 11:40 AM | #14 |
SKINNY TIRES RULE!
Jimmy72custom What kind of Silicone did you use? Does it collect dirt & dust?
jakeslim Where did you get the NOS regulator?
05-21-2006, 12:32 PM | #15 | |
I was lucky, when I bought my blazer it came with the buy. The PO had bought it several years prior, but never changed it out. I'm not sure if you can get them anymore...don't think so. I've never seen one on ebay..well in the last couple of years or so. Maybe someone else can chime in on availability.
05-21-2006, 08:55 PM | #16 |
Thank you for the info Jakeslim.
05-21-2006, 10:05 PM | #17 |
Bouncytruck, I just buy the cheapest spray silicone lubricant I can find. I live on a dirt road and have not had an excesive dust problem. My friend tried it on his Ford (excuse my language) because he was popping the electric window breaker. Cured the problem.
05-22-2006, 03:40 PM | #18 |
Mine has that problem too...I notice my door allignment was off and the top was pushing the upper part of the door out of whack...the spot weld for the door post was cracked.....once I pushed the post back in...window rolled up and down just fine.....I'm sure there's worn out stuff too.
Patch |
05-22-2006, 08:26 PM | #19 |
me too
1964 BBC 402 4x4 |
