Old 05-21-2006, 10:43 AM   #1
EyeH8the24
EyeH8the24's Avatar
69 body on a mid 80's frame
any one put a 69 body on a mid 80's frame ...body mounts pretty close and such ..what all is involved..i just bought a 87 that is is great shape...other then the top of the cab being damaged in a light roll over...bought it to put the front cross member and power disc brake stuff on my 69 ..but after looking at theframe its in a lot better shape than mine....thanks
EyeH8the24 is offline   Reply With Quote
Old 05-21-2006, 11:43 AM   #2
qksilver
Re: 69 body on a mid 80's frame
A lot of people "engineer" the donor body mounts. I have done a few frame swap and founf that using the frame mounts from the original frame on the donor frame works and looks better. Dril/torch/whatever the mounts off of both frames, measure a couple of times and drill and bolt the original frame ounts to the donor frame. Swapping for a later model frame for a 69 is fairly simple, lots of small details but pretty much a bolt together as far as steering, wiring etc. Use as many parts off the donor on your 69 as possible that way they are matched, especially the brake system.
I am in the process of using a 87 donor on my 67, I did not use the frame because mine was in good shape. I am using the master cy;inder booster/brake pedal assembly, the complete front cross member and suspension, engine/trans/drive shaft, wiring harness/steering column/wiper motor, cruise control, seat .
There is very interchangabilty on GM trucks thru the years.
Get out a tape measure and use it a couple of times before cutting/drilling etc and things will go well, also take your time.
qksilver is offline   Reply With Quote
Old 05-21-2006, 11:46 AM   #3
EyeH8the24
EyeH8the24's Avatar
thinkin i may just swap the brake system over..its just a beater truck ..daily driver,trash hauler..lol..but the drums sure do suck...thanks for the input
Old 06-15-2006, 11:41 AM   #4
Ademero
I'm actually going to do this to my 70 long box 2wd. I was going to do the subframe swap and rear axle swap from my 82 chevy, but my buddy talked me into swapping out the whole frame. Plus X=member will be the same for the 700r4 and get away from the 2 piece driveshaft.
Ademero is offline   Reply With Quote
