05-21-2006, 07:11 PM | #1 |
parting out 69 1 ton
got it home did a compression and test and have decided to part it out rather than fix it. Everything will not include shipping. Truck is a 6-cyl (292) auto, pb. Let me know what you want off of this. The heater controls, black arm rests and the dash pad are spoken for. I'll start with:
west coast mirrors-$10 each auto. linkage-$30 metal dust cover $10 Last edited by 67sss; 05-21-2006 at 07:14 PM. |
05-21-2006, 07:19 PM | #2 |
Re: parting out 69 1 ton
oops! wrong place,hopefully MOD can move it for me .
05-22-2006, 10:24 AM | #3 |
does it have the auto crossmember?I need the spacers where it bolts to the frame.thanks
1968 Custom 10 SWB 1970 2wd Blazer 350/400 1972 K20 292/350 |
05-22-2006, 06:31 PM | #4 |
clearance lite pics
bobvilla67- yes it has the auto crossmember, not sure by what you mean about the spacers? |
05-22-2006, 06:47 PM | #5 |
its all about the +6 inches
They are faded pretty bad.. .I'll pass and let some one more desperate than me grab them.
Thanks |
05-22-2006, 06:51 PM | #6 |
I'll take the light lenses!!!!!!
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
05-22-2006, 07:24 PM | #7 |
Robert- yours PM sent
05-22-2006, 08:02 PM | #8 |
Not a bad nut after all..
I'm looking for leaf spring rear suspension exhaust hangers for the passenger's side.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
05-22-2006, 08:41 PM | #9 |
Have a torch? I need the center section of the cross member that the driveline passes through. I only need the center section so if you could cut it on each side of where the rear trailing arms bolt up, that would be perfect. I am in no real hurry so if you wanted to wait until you sold things that made it easier to get to, that would be fine.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
05-23-2006, 12:30 PM | #10 |
I have a crossmember from a 1/2 ton and it is to small for the 1 ton frame I have.someone posted pics from a 1 ton crossmember and it looks like a spacer on the bottom where it bolts to the frame.is the whole croosmember different from the 1 ton and 1/2 ton?I 'm not sure maybe someone can answer.thanks
05-23-2006, 12:34 PM | #11 |
Member #1049
Yes all the AT crossmembers are the same.. the 1 tons have a spacer..
05-23-2006, 01:23 PM | #12 |
Not trying to hijack your thread here but.....so I need a cross member from a 1/2 ton or 3/4 ton only?
05-23-2006, 01:24 PM | #13 |
...and is an automatic cross member different from a stick shift?
05-23-2006, 01:47 PM | #14 |
Member #1049
silvertonguedevil...All of the automatic crossmembers are the same... 1/2ton, 3/4ton and 1ton.. Just the 1 tons used a spacer because the frames are taller..
The manual transmission trucks used 2 different crossmembers which are riveted to the frame under the belhousing.. the 6 cyl is different from the V8.. |
05-23-2006, 02:52 PM | #15 |
We may be talking about different cross members. I'm not talking about a transmission cross member. I'm talking about the cross member that the driveline actually passes through. Some had a carrier bearing and some did not but that's the cross member that I'm talking about. It would be the first one after the tailshaft on your transmission (and the driveline passes through it).
05-23-2006, 05:32 PM | #16 |
Member #1049
silvertonguedevil.. Opss.. my mistake.. yes were are on different pages.. sorry.. I do not know if they are the same between 1/2ton and 1/4 ton.. the 3/4 ton ones could be made of thicker material.. the 1 tons would be taller.. anyone??
05-23-2006, 06:21 PM | #17 |
I'll take some pics later of both x members and maybe that'll help.
05-23-2006, 08:16 PM | #18 |
Do you have a pic of the engine and air cleaner if original? Does it have PS?
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible. |
05-23-2006, 08:48 PM | #19 |
bobvilla- here's a set of spacers for you.
badpeanut-leaf spring rearend pic and a pass. side exhaust hanger. silvertonguedevil- 2 pics of x members for you. chucks70- engine pic for you- only 1 bracket left of the air cleaner setup. I'll check with my cousin, I know he has a complete setup. No P.S. on this. I have a ps gearbox in the shop or are they diff. on a 1 ton. |
05-23-2006, 08:51 PM | #20 |
more pics
05-23-2006, 10:35 PM | #21 |
67sss, thanks for the pics but those cross members are totally different from what I have/need. I guess I need at least a 1/2 ton or a 3/4 ton. Thanks again.
05-24-2006, 12:20 AM | #22 |
no problem...turn em over, I'm sure they'd work.
05-24-2006, 11:03 AM | #23 |
How much for the spacers shipped to 75160?thanks
05-24-2006, 12:39 PM | #24 |
Is it me, or are the mirrors different on each side?
05-24-2006, 02:52 PM | #25 |
How much for the air cleaner assembly shipped to 08753?
Thanks. |
