05-21-2006, 07:48 PM | #1 |
Inner Fender ?
Can you still buy a passenger side inner fender from GM? If so, how much? Thanks Tim.
05-21-2006, 08:02 PM | #2 |
Re: Inner Fender ?
I don't think GM makes em anymore. I'm pretty sure Goodmark has GM licensed repro's if you must have the GM sticker on your parts.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
05-21-2006, 08:35 PM | #3 |
Re: Inner Fender ?
I talked to a guy about a NOS inner fender and was curious what to offer.
05-21-2006, 08:48 PM | #4 |
Re: Inner Fender ?
GM 3882650 right
GM 6270855 left Could run around $130 each, but check around for best deal.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
05-21-2006, 09:00 PM | #5 |
Re: Inner Fender ?
You can still buy them. gmpartsdirect has them
05-21-2006, 09:39 PM | #6 |
Re: Inner Fender ?
Thanks alot.
05-21-2006, 11:03 PM | #7 |
Questionable
Re: Inner Fender ?
i wouldn't shop w/GMParts direct, but at least you can get a rough price to charge.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
