Old 05-21-2006, 09:13 PM   #1
roj2323
to powder coat or not to powder coat.
hey all,
well, i'm painting my frame in a week or two but i was concidering powder coating some of the other parts. i am wondering what specificly i should concider powder coating and what i really don't need too. i know this sounds weird but here's my reasoning:
i'm painting the frame because i have shaved close to 200 holes and i need to put some filler on it to make it smooth and mirror like in apperance. however i know the spindles will likely rust if i paint them so powder coating is probably adviable there. ... beyond that what do you think?
ondrew
roj2323 is offline   Reply With Quote
Old 05-21-2006, 09:18 PM   #2
roj2323
Re: to powder coat or not to powder coat.
oh i forgot. i posted this to the 67-72 board because it's a 71 and the answers i get will probably be more usable if they're catered to what i'm building. i hope you understand.
Old 05-21-2006, 09:22 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would use POR on it all...esp looking at your location.
Old 05-21-2006, 09:40 PM   #4
roj2323
i here POR 15 is prone to fading and doesn't like non rusty surfaces though. what's your experince with it longhorn? also do you think it would adhear to DP40?
ondrew
Old 05-21-2006, 09:42 PM   #5
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
I would powder coat it, the power steering gears we make at work get powder coated, they go into heavy duty semi's and they last quite a few hundred thousand miles, besides powdercoat gets shiny after you cook it
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 05-21-2006, 09:49 PM   #6
ChevyDude
I just did mine well a good bit of the parts and if I had to do it again....EVERTHING would get powder coated. Frame and all the undercariage parts.
ChevyDude is offline   Reply With Quote
Old 05-21-2006, 10:28 PM   #7
Longhorn Man
Well, the over the road trucks I work on every day have the powder coat on them, and they are all flaking off and letting the rust build up underneath.
As for being non CV resistant, that is correct, but a quick coat of paint fixes that. And if you shoot the paint when the POR is still tackey, then there is no sanding needed, no primer needed, and it will pretty much never come off. It will be one wioth the POR.
As for sticking to non rusted items, 99% of the time I put parts in the sand blaster and then POR them, have yet to have a problem.
However, i wouldn't apply it over the primer you already have on there.
Old 05-21-2006, 10:38 PM   #8
kansas city cheyenne
Rebuilding 1 at a time
kansas city cheyenne's Avatar
I have used por and so far its been great, I would look at that option before spending the money to powdercoat. I think you will like the results with por.
71 cheyenne lwb
383 stroker
2004R tranny
Factory ps, pb, air
http://smg.photobucket.com/albums/v3...t=101_0059.jpg
66 Nova SS L-79
327
m21
http://smg.photobucket.com/albums/v3...t=101_0042.jpg
kansas city cheyenne is offline   Reply With Quote
Old 05-22-2006, 12:11 AM   #9
roj2323
should i POR 15 , apply filler then topcoat?
Old 05-22-2006, 01:33 AM   #10
local13hutch
MEMBER
local13hutch's Avatar
roj2323...longhorn man..is exactly right in my opinion.first off everything I have ever powder coated gets scratched sooner or later and then I end up doing a touch up with paint anyway because you cant touchup with powder coat. And any time you sand blast then paint you have got a perfect surface for paint. paint is the way to go but keep in mind that the thicker the paint the more likely it is to separate or peel. A lot of guys think that thicker is better but it just isnt the case. In the old days it was 20 coats of whatever and then later on it cracks and shrinks. Nowadays the pros use less coats with better results... OK I'll shut up now ..just my two cents ... but keep in mind I work on the ocean.. salt water..I used to prep and paint ships....
86 sub 4wd, 1 ton, duallie, big block th475
72 c10 short fleet, pro street
72 K/5 blazer,2x4 almost stock
72 3/4 ton sub 4x4
61 morris minor pickup, chevy 4.3 v6
03 escalade, 24" momo's wifes
96 2wd 2door tahoe
67 2wd suburban
72 4wd k5 99 vortec 14bolt/d60 205/th400- 72 4wd crewcab 1 ton sb cummins allison -2012 2ss camaro black hard top- 8 yamaha quads- 05 4wd one ton duramax dually, family limo.
local13hutch is offline   Reply With Quote
