Old 05-21-2006, 10:10 PM   #1
62 short step
62 short step's Avatar
60-66 4x4 steering
Hey can someone post some pics of there 60-66 4x4 steeering by the drivers side, mine does'nt look right to me. Just want to make im riding around safely. Thanks Jeremy
62 short step is offline   Reply With Quote
Old 05-22-2006, 01:28 PM   #2
Prerunner1982
Prerunner1982's Avatar
Re: 60-66 4x4 steering
posting a pic of yours might help as well...they are really pretty easy..
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 05-23-2006, 01:17 PM   #3
Americanrider
Are you still running a closed Knuckle front axle?
Americanrider is offline   Reply With Quote
Old 05-23-2006, 04:12 PM   #4
62 short step
Yes I am,what doesnt look right is the, I guess its called the draglink from the pitman arm to the arm on the knuckle. I have a LMC truck mag that shows the part and mine doesnt even come close to looking like it, and of course this part is not available. OK got my assembly manual out and they call the part a connecting rod assembly. I guess I could use two tie rod ends and a connector? Let me know Jeremy
Old 05-25-2006, 11:16 PM   #5
Americanrider
awaiting pics...
Old 05-26-2006, 06:57 AM   #6
62 short step
I'll have pics for you when I get home after work today. Thanks
Old 05-26-2006, 06:24 PM   #7
62 short step
It’s the draglink I'm trying to figure out. Obviously its not the stock one, somebody rigged this one up. My pitman arm has a threaded 3/4 hole and the steering arm also has a 3/4 hole. So my question is do they make tie-rod ends to fit that size hole? I know I will have to taper the steering arm and the pitman arm for the taper on the tie-rod. Here is a picture of what I have now. Thanks.
Jeremy
Old 05-30-2006, 06:29 PM   #8
62 short step
I guess the heim joints will work for a draglink?
Old 06-10-2006, 02:52 AM   #9
Americanrider
I just threw one of those away last month from a 69... dang it! I'll look around and see what I can find. Are you wanting to replace your drag link back to stock? It looks solid from the pic but.... lives are riding on the quality of work, yours included.
Old 06-10-2006, 02:08 PM   #10
62 short step
I asked around on some 4x4 boards and there saying its stronger or just as strong as the tie rod made draglinks. So I ordered some new parts to rebuild it. Thanks Jeremy
