05-21-2006, 10:21 PM | #1 |
c30 frame?
i'm kinda planing for a new project. thinking of putting a 72 cab on a 80 1 ton frame. how does the width compare? i know ill have to do some work with cab mounts but wondering if i can just redrill the frame and bolt them on or move them in or out. i have my choice of the 80 cab and chasies or a 69 GMC 1 ton but the 80 has been well maintained and just recently retired by a tire and allignment shop due to nolonger doingon road service for farm and road construction equipment and the gmc has been in the junk yard for years so ide opt for the newer chasies. i think this is the truch that will get the 500 insted of my 4x4
common sense isn't so common anymore |
05-21-2006, 10:30 PM | #2 |
its all about the +6 inches
Re: c30 frame?
I *think* the cab will sit on there pretty close to right, the mounts for the cab on the frame will need addressed,a nd you may have to add some shims or even small spacers, but the main issue will be with what kind of bed you add.
Again.... if I remember right. Mudder is THE man to talk to on this. |
05-21-2006, 10:32 PM | #3 |
I have a radical idea!
Re: c30 frame?
I think the width is about the same because the front suspension from under a 73-87 will bolt under a 67-72 almost directly (you have drill a few holes). The newer chassis will be the way to go for sure. Disc brakes and 14 bolt rearend instead of the good, but hard to get parts for Eaton rearend.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 05-21-2006 at 10:34 PM. |
05-21-2006, 11:30 PM | #4 |
Re: c30 frame?
for a bed it will probably start out as a ramp deck car hauler till i find what i need to put a small dump box on it. it now has a 14' van box that don't come with it
05-22-2006, 06:53 AM | #5 |
Re: c30 frame?
That makes it easier,no bodylines to line up.This is what I plan with my Suburban(`91)installing a 67/72 cab`n`clip.Then,a utility bed.They say Suburban frame contours are different than trucks(even in same year),but I measured hub to hub(front to back)and it`s the same on the`Burb as my`72 K/20.I`ll be going for it as soon as I can stop using the`Burb for my main transportation(soon).
