Old 05-22-2006, 11:47 AM   #1
355
355's Avatar
Nitrogen
Why do I need N2 in my tires? I have always put air in them before and now the sales person informs me about the error of my ways. The nitrogen will keep the tire cooler, will improve MPG, will not break down the rubber, and bring me a beer if I am watching TV. Well....... if anyone else can inform me on what else I have been missing, lets share. Steve
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2.
355 is offline   Reply With Quote
Old 05-22-2006, 12:05 PM   #2
mocwon
Keep On Truckin'
mocwon's Avatar
Re: Nitrogen
that's a new one on me... maybe he sells Nitrogen too...
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 05-22-2006, 12:33 PM   #3
sleepyboy
'69 Step
Re: Nitrogen
how come they come from the factory with room air in them then??
sleepyboy is offline   Reply With Quote
Old 05-22-2006, 01:00 PM   #4
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Nitrogen
Air=79% Nitrogen+21% oxygen
hgs_notes is offline   Reply With Quote
Old 05-22-2006, 01:39 PM   #5
cdowns
cdowns's Avatar
Re: Nitrogen
actually it would be an awefull lot better to use helium that way you'd get a feeling of floating over the potholes and your truck wouldn't weigh as much and your beer would be colder
Old 05-22-2006, 03:31 PM   #6
724wdcopper
graphic designer
724wdcopper's Avatar
Re: Nitrogen
nitrogen molecules are larger, therefore are less likely to escape and it is more stable, ie you won't get as much pressure variation when the tires heat up. if it's free, great, but don't go paying for it unless you have a race car...
724wdcopper is offline   Reply With Quote
Old 05-22-2006, 03:43 PM   #7
70rs/ss
70rs/ss's Avatar
Re: Nitrogen
I was going to throw in there that racers use it. It is more stable and expands and contracts less than just "air" I can't imagine a fill up with it being too awful expensive, but I have been wrong before.
70rs/ss is offline   Reply With Quote
Old 05-22-2006, 03:46 PM   #8
70GMCer
70GMCer's Avatar
Re: Nitrogen
I have 2 tanks on my service truck and I have used it when I have had a flat tire (slow leak), until I get it fixed.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-22-2006, 04:10 PM   #9
chevyboy55
chevyboy55's Avatar
Re: Nitrogen
We used to use it race car tires cause it won't heat up & expand like air will & mess up your stagger, but it seems kinda crazy to use for street cars.
chevyboy55 is offline   Reply With Quote
Old 05-22-2006, 06:33 PM   #10
truckdude239
truckdude239's Avatar
Re: Nitrogen
okay i work for sam's club tire and battery as a master tire tech. what he said is true the biggest advantge is it doesn't leak out as fast as air. my job looked into going to nitrogen but for the price its not that friendly for us to put in tires. its easlier for us to just check the pressure when ever they come in for a rotation (every7500 miles)
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-22-2006, 07:01 PM   #11
Sweet72
Sweet72's Avatar
Re: Nitrogen
We use dry nitrogen in aircraft tires...never thought much about it but maybe it won't support combustion??? It has no moisture or oxygen to cause oxydation. I guess its all about safety.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 05-22-2006, 08:02 PM   #12
Chevrolet4x4s
Chevrolet4x4s's Avatar
Re: Nitrogen
For a street vehicle in my opinion...for a race car its legit.....Can you say OVERKILL
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 05-22-2006, 08:48 PM   #13
Psycho71
Psycho71's Avatar
Re: Nitrogen
I imagine the reason it is used in aircraft tires is the extreme temp. differences experieced. On the ground the ambient temps would vary greatly compared 10,000'+. This might create a massive pressure swing with air, especially if the tires were inflated in an extremely humid climate then climbed to 30,000', then rapidly descended to sea level. It would probably be like landing on Marshmallows.
Nitrogen is dry, and yes inert, and not as suceptable(sp?) to temp changes.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
