Do you guys recommend replacing original fuel lines for 72 Blazer since there 34 yrs old. If so, wheres the best store to order them? And also, where do they sell the gas filler hose for poly gas tanks?
Re: ?:Fuel lines for 72 Blazer
Just go to auto parts store and buy lengths of 3/8" brake or fuel line and connectors and bend your own. They should have hose also.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
SKINNY TIRES RULE!
The fuel lines should be metal tubing. I don't think there really isn't any reason to replace them unless they are bent, damaged or clogged.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Thanks guys for the info. Maybe it doesn't need replacement afterall. My fuel lines are not bent, damaged, or clogged. They problably just need cleaning with an air pressure compressor. And like what parts store has the gas hose. Ive asked like napa, autozone and dont carry it.
SKINNY TIRES RULE!
Napa should carry it. I'd try another Napa.
Thanks, ill keep that in mind.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
May want to try some board vendors???
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
