Old 05-23-2006, 01:10 AM   #1
John Fabris
TOTY 2006
John Fabris's Avatar
goodmark replacement door handles...
Just got a set of goodmark outer door handles, and they do not work.....
The holes on the handles are 1/8 to 3/16 of an inch off.
Anyone else try these and had success? Granted I only paid $40 for the pair.
Makes me more willing to pay $125 each for the NOS ones.......
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 05-23-2006, 06:53 AM   #2
mbgmike
Re: goodmark replacement door handles...
Yeah the door handles are not for 67'or 68. They are 69-72. Also the right side seems to be better made than the left if you look inside at the casting.the right seems thicker.
mbgmike is offline   Reply With Quote
Old 05-23-2006, 08:16 AM   #3
Tim Christian
Tim Christian's Avatar
Hey John, mbgmike is correct. I had the same problem with my 67 So I tried the GM NOS ones they were worst than the aftermarket ones So I keep going through diffrent ones untill I found two that I liked. The only bad thing is everybody don't have a shelf full of them.
Tim Christian is offline   Reply With Quote
Old 05-23-2006, 10:48 AM   #4
Bob Moore
John - What do you mean they don't work? Are the pins too short? I have heard this before.
Thanks for the info - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 05-23-2006, 12:06 PM   #5
John Fabris
TOTY 2006
Hi Bob,
The two holes for the bolts (that hold it onto the door) are drilled such that when you line up one hole, the other hole is 1/2 to 1/3 covered up, so you are unable to get the bolt to thread into the handle. I may play around with opening up the holes on the door just a little bit.
John Fabris
67 C10 SWB
Old 05-23-2006, 02:09 PM   #6
shifty
Questionable
shifty's Avatar
Go to Brother's - they are having a sale on all of theirs (this is what the brochure said the other day).
www.brotherstrucks.com
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 05-23-2006, 06:08 PM   #7
uncle
I think the 67 handles were a little different even from the factory. I'm sure one of the more knowledgeable guys will kick in shortly.
uncle is offline   Reply With Quote
Old 05-23-2006, 06:19 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have heard that many of the repro handles break within a year or two also.
Old 05-23-2006, 08:09 PM   #9
John @ BROTHERS
John @ BROTHERS's Avatar
We have had more troubles with the "original" GM handles then we have had with the repros. Plus the chrome is much nicer on our repos then any of the GM. The problems we have had with GM is the guide plate on the back. The tabs that hold it in break off. The other thing is price. GM's cost is way up there. You can get a set of the repro for the price of 1 GM handle. Just my 2 cents with what I've seen over that few years.
1967 Chevy Short/Fleet
1969 Chevy Short/Step
2004.5 Dodge 2500 4x4 Cummins 6spd
John @ BROTHERS is offline   Reply With Quote
Old 05-23-2006, 08:32 PM   #10
mbgmike
Yes we have heard that from some customers also. Then some have lasted to. If its less than a year we generally give them there money back.(just don't spread it around)
Old 05-23-2006, 08:42 PM   #11
mbgmike
I agree and they get worse in the 80's Look the 90's they fixed the outside the the inside kept breaking off I replaced 5 of them 245.000 miles.
Old 05-23-2006, 10:02 PM   #12
I got my set from GMC Paul's and haven't had a problem in 2 years. Chrome is still great and they work super smooth. Everything matched up fine also. Not sur who they were made by, but they were not that expensive.
Old 05-23-2006, 10:28 PM   #13
64fleetside
my bro had the Goodmark handles corrode in about 18 months. They still work fine, but look worse than the 37 y/o ones he had originally. brian
64fleetside is offline   Reply With Quote
Old 05-24-2006, 08:57 AM   #14
Joe67
67 is sold
How many companies actually make the repro door handles? One or two?
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
