Old 07-31-2002, 10:00 PM   #1
Sinister
Between Trucks...
Sinister's Avatar
Angry help with HEI install...
got it in...
won't start, back fired a few times, got spark, plugged into ignition in the fuse box, everything was set at tdc, plug wires are correct...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-31-2002, 10:11 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
ttt
really bumming guys...
Beat it to fit,
Old 07-31-2002, 10:22 PM   #3
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
is it 180 out?
68SWB4x4 is offline   Reply With Quote
Old 07-31-2002, 10:29 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
uhhh, could be, how would i check that? i brought it around to what i assumed was tdc...
piston seemed to be up top...
i should of checked the position of the rotor on the old distributor but i didn't...
it's backfiring a little bit (loud), but don't wanna start...
Beat it to fit,
Old 07-31-2002, 10:50 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
hey 68SWB4x4, you're no jacka$$ you kick a$$!!!
180 out, that was pissing me off...
thanks a million...
Beat it to fit,
Old 07-31-2002, 10:51 PM   #6
brad69C-10
ummmmmmmm.....I usually take out #1 plug and stick your finger over the plug hole, while you (with a remote button) or someone else bumps the engine over. When you feel the rush of air blow out the hole, the rotor button should then be pointing in the general direction of the #1 cylinder. If it is aiming to the back, then it is 180 degrees out.....Although you can realisticly put number 1 where ever you want it, this is generally the way it should work.........hope this helps
69 C-10 Pro Street...........red on black...........big block and a lot of go fast stuff under the hood
Still in progress ...........
brad69C-10 is offline   Reply With Quote
Old 07-31-2002, 10:51 PM   #7
brad69C-10
COOL.I see you got it, as I was typing.......lol
Old 07-31-2002, 10:52 PM   #8
lux hauler
Psycho-billy Member
lux hauler's Avatar
Bring the number one piston to TDC on the compression stroke (pull the number one plug and you should feel air pushing out of the hole as you come to TDC). Pull the cap off and check the position of the rotor. Does it line up with the number one spark plug wire? If not, you will need to lift the distributor and turn it so that it lines up.
ok........I guess you got it.......lol
'72 C-10
350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers.
Support your community, support yourself. Buy local, buy American (or Canadian).
lux hauler is offline   Reply With Quote
Old 07-31-2002, 10:55 PM   #9
Sinister
Between Trucks...
Sinister's Avatar
AAAAaaaeeeeee!!!!!
damn i'm an idiot...
i'm gonna go for a spin and try not to get a ticket...
thanks...
Beat it to fit,
Old 08-01-2002, 01:23 AM   #10
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
glad i could help, now tell us if theres any power, or mileage improvment
Old 08-03-2002, 11:30 AM   #11
Sinister
Between Trucks...
Sinister's Avatar
definitely an increase in power, will try to figure out mileage, but it ain't worse...
i need to mess with the advance curve, possibly an adjustable vacuum advance,
really worthwhile addition...
thanks everybody...
Beat it to fit,
