Chance
![]() Join Date: Sep 2001
700r4 TV cable/problem HELP!!!
I finally got my 396bb running smoothly but I am having a problem with the 700r4 transmission. First of all the transmission took about 13 quarts of trans. fluid for it to move. Then once it moved I have to rev it up for it to pick up speed. I know there is a problem because the engine rpms are too high and the transmission jumps up through the gears way too quickly. Do any of you guys have any suggestions? At wide open throttle there is no slack on the tv cable? I never took off the pan when the tv cable was set.
Chance
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
Re: 700r4 TV cable/problem HELP!!!
First off, it took 13 quarts for it to move, but did 13 quarts fill it up exactly to the full mark? The few 700r4 I've had experience are real particualr about the fluid level being axactly right.
I'm looking for a link to a page that explains how to set the tv cable correctly. brb |
Out draggin'
The TV cable is supposed to be set with a pressure guage. You have to put a PSI guage into one of the pipe plugs on the side of the trans. If you don't have the proper specs then it would be best to let a trans shop do it for you. If not, you WILL burn the trans up, quickly...
91 GMC Xcab LB-Bags/bd/caddy clip SOLD 72 C10 Cheyenne Super LWB SOLD 92 GMC K1500 Burb 72 C10 Burb (ex. Cheesewagon)SOLD 72 C20 Burb parts truck 71 C10 Burb "project" |
Chance
It has more than enough fluid because it says so on the dipstick. It's like it is not taking it's oil because. What do you think?
try this page http://www.tvmadeez.com/article/index.php
lotta good info including how to set the tv cable. |
Oilfield Trash
There should be a button on tv cable where it set sits in the carb bracket, press the button in and pull on the cable from the backside until it stops (actually pulling on the plastic tube) release the button and turn your carb to wide open throttle the tv cable should automatically set itself, should hear "clicking" as the tv cable comes out the first time, this is how i did mine and has worked great for years
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
its all about the +6 inches
You might want to look at www.bowtieoverdrives.com too, they have the parts you'll need to get it 100% right.
Since you have it in a nonstock aplication, you need to do more than a pop the adjuster, floor it and click it in place. Blue85 may have gotten lucky, he may have it all on a stock engine that was intended for that tranny, but many people have ruined gm overdrive trannys due to misadjusted TV cables, even if it feels right, it can still be in self destruct mode. And you'll never know untill one day it simply won't move. Last edited by Longhorn Man; 05-23-2006 at 03:36 PM. |
![]() Join Date: Nov 2004
I know that a 700R4 should take 5 quarts for just the pan alone. If your trans and torque converter were completely empty when you filled it then it will take much more than that. I think mine took 12 or 13 quarts when completely empty. I'd check it once the trans is warm and it should be at the proper level. You don't want too much fluid in it either because that will cause problems as well. I'd recommend the BO kit. Takes out all of the guess work. Also, did you use a lock-up kit with a brake switch for the torque converter?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Oilfield Trash
Longhorn man, it was a warmed over 355 small block in my 85 chev i used to have worked great for 5 years, must have gotten lucky i guess.
i adjusted my TV with the manual adjustment had over 80K miles on it with no problems i think bowtie overdrines is very orerrated
![]() Join Date: Dec 1999
Go to the Website that Tugowar recommended. TVmade EZ it is a site by Bowtie Overdrive and it will get you where you should be with that transmission! That's the way I set mine and have had no problems at all!
Smitty '71 Short Fleetside Spring Valley, Ca. |
CDowns may be right. But if you are unsure and want it right so that you aren't throwing money into repairs it is an excellent way to do it!
#13 |
Chance
I called Mad Dog Transmissions and told them the problem. After telling them the installation process I used they recommended sending out a "light weight" governor that should correct the problem. If that does not correct the problem they'll do what it takes to make sure it's working properly. They are really helpful and patient. One thought though. Doesn't the governor control the forward gears and not have anything to do with the reverse? Because all the gears, R, OD, D, 2, & 1, all require high rpms. For example, my truck was running at 3500rpm in 3rd gear only going 45mph. Since the 700r4's first two gears are lower than a th400, I should have been just getting into 3rd gear at that speed. What do you guys think? I want to drive my truck
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 Last edited by cwilkie; 05-24-2006 at 10:03 AM. |
#14 |
gov isn't going to do anything, sounds like they are throwing parts at it to me.
#15 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I know this may sound like a dumb question, but are you sure the trans is in good working order? Where did it come from and do you know if it has been rebuilt? I have a 700R4 sitting in my garage that is going into my 72 Long Box 396/350 HP.. I know that my trans has only 25k on it since a complete rebuild and I'm curious to see what your problem actually is so I can maybe avoid it when I get mine installed.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#16 |
under light load normal driving conditioons you should be into 4th gear by 40mph
#17 |
Chance
My mechanic/father thinks that as well. The tranny seems like it is not building any pressure. Kinda like the filter is plugged. I guess I'll have to go through the process of elimination. I got it from Mad Dog Transmissions and it is supposed to have a one year warranty so we'll see. This situation gets to me because I spent a lot of money on that transmission and I waited a long time to get my truck running after the rebuild and now I can't drive it. Suggestions are welcome.
#18 | |
#19 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here's TCI's site for fluid capacity and there is a menu on the left with several pages of info and line pressure is among them. Of course no one will go and look at them cause they never seem to notice when I post a link. Sob!!
http://www.tciauto.com/tech_info/fluid_capacity.htm
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#20 |
Chance
VetteVet, I'll check them out. I have nothing else to do until that governor arrives. This sucks though. I paid a good amount of cash for a rebuilt transmission and my truck can't even move. Well Rome wasn't built in a day so I guess I'll just have to continue to be patient and see what happens. I would like to thank all of you for all your help and I will keep you all posted on this matter. Hopefully that part will come in by tomorrow so I can get to tinker with it all weekend.
On a different note. I mentioned my motor was rebuilt because I wanted .060 pistons in my 396bb and I also wanted to change from open chamber to closed chamber heads. Now is it just me or does the closed chamber heads have a big difference in sound. It's almost like my trucks seems to have a crisper sound from the exhaust. Or am I full of $hit? Oh, please keep the advice on the transmission coming.
