Old 05-23-2006, 03:42 PM   #1
76bonanza
76bonanza's Avatar
rear drop question
My rear drop is supposed to be 4 inches. I am redoing my rear drop because the PO used 4 inch blocks and I am going to drop springs. My question is I like the hieght in the rear but not sure how old the coils are now so dont know if it is 4 inch or not. I am running 275 60 15 tires and it sits about 30.5 inches to the high part of the wheel wells to the ground. Does this sound right? I just want to make sure 4 inch drop springs will leave me in the same general area.
Thanks for any help
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 05-23-2006, 03:48 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: rear drop question
Try measuring from the frame to the axle tube. ECE claims a 6" drop will leave 3" between the frame and the axle. So we can assume that a new factory spring will leave 9" between the frame and axle. Do the math from there to figure your amount of drop or sag.
see ten is offline   Reply With Quote
Old 05-23-2006, 06:59 PM   #3
Gennoy
Gennoy's Avatar
Here was a picture of mine with a 4" drop spring in the back and an old L60-15 on. That tire should be 27.9" tall which is close to the same size as a 275/60R15 (28"). Maybe the tires were a little flat cause it doesn't look like it is 27.9" tall in the picture. You can tell the top of the wheel well is about 29.5 inches or so.
1969 Chevrolet C-10 SWB
Gennoy is offline   Reply With Quote
Old 05-23-2006, 08:37 PM   #4
76bonanza
76bonanza's Avatar
if this is were I am supposed to messure. it is like 4 and 1/8 inchs so by your calculations see ten it is closer to a five inch drop. The blocks are 4 inches exactly and about 3/4 inch of sag. Does this sound right? So if I get ECE's 5 inch rear drop kit. With springs shocks and all the fixins it should leave me close to the same? I dont want to get it lower than the front it is about 3/4 inch rake now would like to get as close to level as possible with out going over. I think that ECE kits has all I need yes? I dont need to notch it or anything do I.
1968 c10
lowered 3" 4"
Old 05-23-2006, 09:57 PM   #5
see ten
WTB this ad
see ten's Avatar
To me it looks like 5" would put you right were you want to be. Give the guys at ECE a call and bend their ear a bit. I am sure they can point you in the right direction. A notch shouldn't be necessary for 5". ECE claims you don't need a notch with 6" but I think it wouldn't hurt.
Old 05-23-2006, 10:26 PM   #6
70c10
67-72 Addict!
70c10's Avatar
I have 4" drop springs on the rear with 275/60/15 and I think mine is also 30.5".
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
