![]() Join Date: Feb 2001
Blazer going under the knife, some ?s
I've got a 72 Blazer and a 72 Jimmy I'm about to tear down and build one using parts from both. One is rusty and one is dented up. How hard is it to change out bedsides - do they unbolt or do you have to cut them out? Is it possible to make a Blazer door by cutting the top section off a truck door? It looks like it will work, but I want to make sure before I go hacking up some good truck doors. I'm just getting started and I'm sure I'll have some more questions as I go. Thanks for any help!!
Joshua |
![]() Join Date: Dec 2002
Re: Blazer going under the knife, some ?s
Bedsides unbolt and have a few spot welds. Goo thread by VT blazer showing how to change a bedside. Doors are the same you will need to take off reinforcing plate off blazer door that goes around latch and weld on. Also the little wedge at the back
SKINNY TIRES RULE!
I think it was VTBlazer that posted some pics about a bedside swap. Hopefully someone will be able to post a link to the thread. It might be in the FAQ's, but I've never been able to find anything there myself.
Truck doors can be cut down for Blazers & Jimmy's. I believe the Blazer/Jimmy doors have some added reinforcement but other than that they are the same. The "Factory Service Manual" shows where to cut. They are a decent reference if you are going to be tearing your rigs apart. Most of the board vendors can get them.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#4 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
PROJECT 7DEUCE
Kurt is great about shareing metal working stuff..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
If you don't want to cut down truck doors I believe GMC Paul has blazer doors already cut.
It it ain't broke..don't fix it! |
