05-23-2006, 04:59 PM | #1 |
Clutch Size in my 1968 anyone?
I am just about ready to finish the macine work on my 383 for my '68 but need a 400 flywheel because I am running a Muncie car 4 speed behind it. I was wondering what size clutch I have in there now is?It has a 350 and was originally a 3 speed manual on the column before I put the Muncie in. Anybody know if its a 11" clutch or 10.5"? Thanks again!!
Douglas.
-1968 Chevy SWB = Frame Off/383/Muncie Car 4 speed -1968 Chevy SWB = numbers matching 307/Truck 4 speed. -1966 Chevy II = 2 door No Post/130,000 Orig miles/230 6cyl/powerglide/Vintage AC -1972 Chevy Nova = 2 door/412 Small Block -1927 Ford Roadster = Homebuilt/widened 8"/350/ Custom Everything. |
05-23-2006, 05:12 PM | #2 |
Re: Clutch Size in my 1968 anyone?
11 inch from factory
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
05-23-2006, 07:42 PM | #3 |
Right on Thanks. Also wondering if the 400 flywheel will fit in the bellhousing?
Douglas.
05-23-2006, 07:50 PM | #4 |
its all about the +6 inches
the 400 fly wheel will fit...but they are hard to come by. Good luck.
05-24-2006, 09:40 AM | #5 |
I have seen them aftermarket for around 120 bucks. Which I think isn't too bad is it? Thanks again for the info!
Douglas
05-24-2006, 12:32 PM | #6 |
The clutch size that came off of the 327 was 12", but that is for the 4 speed heavy duty with a 14" flywheel, 168 tooth.
83 GMC Vandura 1 Ton 84 Chevy S-10 4x4 Durango 84 Ford 1 ton Cargo van |
05-24-2006, 08:52 PM | #7 | |
