Old 05-23-2006, 07:48 PM   #1
shortbed70
shortbed70's Avatar
Zing the frame Q's
I did a search and cam up with nothing really. I'm wondering is where all the cuts are made and what else is involved in the front.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-23-2006, 08:05 PM   #2
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
Re: Zing the frame Q's
Try a pm to 7deuce he has a wicked slammed truck with all that done and he just put in a post somwhere if anyone had ?s he would be happy to answer them Also check out the www.ifcustom.com. they call it a stock floor bodydrop but if you look at the pics you can get an idea what was cut and where. There are a couple other guys on here that have some nice ones done too but I can't remember thier names. I actually asked 7deuce a question myself and he was really helpful.
Oldtruckfanatic is offline   Reply With Quote
Old 05-23-2006, 08:58 PM   #3
7deuce
Sold! 2 days after finished
7deuce's Avatar
Check www.loweredd.com And follow the yellow brick road. Remember you need to have an end goal of how low you want to be and what suspension you are going to use before you start the Zing. I only Z'd mine 2 3/4" but I did a TON of other sh%t to get the end result. Ill help you out any way I can. CUT IT TO THE ROCKERS...................
7deuce is offline   Reply With Quote
Old 05-23-2006, 09:00 PM   #4
Oldtruckfanatic
Truck junkie
^^^^^See what I mean...I don't know this guy but I like the way he thinks
Old 05-25-2006, 07:02 PM   #5
laidout86
hey 7deuce question for ya...im zing mine next weekend got that under control but then i was gonna cut the bottom of the frame off to be bd...when i cut the bottom off the frame do i need raise the tranny up anymore or will zing it raise it enough?
laidout86 is offline   Reply With Quote
Old 05-26-2006, 12:49 AM   #6
FnLow69
FnLow69's Avatar
hey laidout86, i wouldnt cut the bottom of the frame you might run into a problem getting the frame down due to not enought suspension travel... why not move the cab mounts down the +-1" needed and raise the trans tunnel up that much more? just a thought...
FnLow69 is offline   Reply With Quote
Old 05-26-2006, 11:25 AM   #7
7deuce
7deuce's Avatar
I Z'd mine 2 3/4" which I wish I would have done a 3 or 3 1/4". Once you Z the frame the motor and tranny will be in place and all you have to do is make a new tranny Xmember (REMEMBER YOUR EXHAUST HAS TO RUN UNDER THERE TOO) So think about your Xmember before building. As far as running the 2x4 box and hacking the bottoms of the rails, thats what I did, I was layin body HARD. Too hard for me I wanted to frame out before I killed the body, but after taking the 2" off the bottoms, your rockers, bed sides and front fenders ALL need to be cut down. I dont know how low you want to go, fab skillz, ect. I would first measure how much frame hangs down below the body and go from there. You might be able to get away with 2x5 box. Also what year is your truck. This is what I know for the 67-72 style. Any other questions let me know. Just dont be lazy and retarded and Z the frame like 5" You can cheat some suspension clearance here and there. Just gotta be smarter than that dumb ol' truck. 412BEATDOWNCREW
Old 06-08-2006, 04:15 AM   #8
BK
BK Built
BK's Avatar
if you go to page http://www.cardomain.com/ride/738021/6 it has some pics from my 4" z. sorry, im just too lazy to save the pics to my friends computer which im on then post them. next page has the stance of the truck. I also had a modded ECE auto tranny crossmember and the ECE trailing arm crossmember btw.
BK is offline   Reply With Quote
Old 06-08-2006, 01:19 PM   #9
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
So how much do you think would be neccesary just to lay frame on 22s?
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 06-08-2006, 08:33 PM   #10
7deuce
7deuce's Avatar
I put a set of 22's on mine today with 255/30/22 and there the same size as my 255/35/20 BUY, Because I didnt narrow the front clip " check out camaro thunder or ifcustoms" They are about3/4 of an inch too wide for the hood. If your going foe double deuces than I think it would be wise to narrow the front about 3".
Old 06-08-2006, 08:34 PM   #11
7deuce
7deuce's Avatar
Are you going to cut the bottoms off your frame? This is what I did.
Old 06-09-2006, 01:20 PM   #12
bagged69c10
No, I dont want to lay body, just frame. Hopefully I wont have to narrow it. Ill find out soon enough. Im starting on it this weekend. Ill try to post pics.
1965 c-10 long bed
1993 Sierra x-cab
Old 06-09-2006, 03:13 PM   #13
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
OT represent! I can't wait to see that thing done. You need to hurry up and get ya some.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 06-09-2006, 04:55 PM   #14
bagged69c10
Not gonna be reppin OT after tomorrow.
1965 c-10 long bed
1993 Sierra x-cab
Old 06-19-2006, 11:30 PM   #15
laidout86
o wow some people from florida....67 fleet i saw ur truck on sat at the blockbuster parkin lot i was in love!..im bringin my to the shop 2morrow..i cant wait...7duece i decieded to not bd it just frame it for now on 22's...so im gonna z it 2 3/4 u think it will be enough? i dont want to go to much and run into problems with distrubtor hittin firewall...hopefully u can help me out...
Old 06-20-2006, 07:29 PM   #16
7deuce
7deuce's Avatar
I moved my motor up to the front set of hole which was 3 inches ( now I need a longer drive shaft) and I Zed it 2 3/4 and I destroyed the HEI. I was bairly able to get the cap off. All you need is $225 for a mallory unilight distrubtor and problem solved. If you just do the Z and leave the stock frame rails alone youll be fine. I ran 2X4 and cut the bottoms off and still laid out with a 2 3/4 Z. INDY OR BUST.......
Old 06-20-2006, 08:22 PM   #17
bagged69c10
Did you buy that Mallory distributer? What size wheels are you runnin? I Zd mine 3" and plan on moving the motor to the front holes also.
1965 c-10 long bed
1993 Sierra x-cab
Old 06-20-2006, 09:43 PM   #18
7deuce
7deuce's Avatar
Yup, there is no problem with the unilight. Its the way to go. The HEI is WAY too big.
