05-24-2006, 03:54 PM | #1 |
Question on shocks for members running 4" rear drop
I've searched and read many of the posts about this topic.
I have a 71 C10 coil sprung rear...4" lowering springs. Front I used 2.5" drop with spindles so I bought the KYB 5409 for the front. Have seen opinions that a 4" drop is not enough to require shock relocators and lowering shocks....some that say it is....I saw in one post that 5409's can be used on the rear also. The KYB 5416 is the matching rear stock shock, will these work without a relocator and 4" drop? Is there another p/n that I can order that is shorter, and will work without a shock relocator bracket? Or is the shock relocator the best overall solution??? Thanks in advance for the help (moved this here from the suspension board).
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
05-24-2006, 07:53 PM | #2 |
Re: Question on shocks for members running 4" rear drop
Some people just run stock length fronts on the rear...
05-24-2006, 10:35 PM | #3 |
Next project: 1970 K10
You don't need special length shocks for the front if your are just using drop spindles with stock heigth springs. The only things that moves location is the spindle, the shock is not changed. I had 4.5" in the rear, and I flipped the lower shock mounts and ran stock length shocks. No problems. I made new upper brackets for when it goes back together. It will have a 6" rear drop then.
Flipping the lower brackets is probably the quickest and cheapest way. I think at 4" you would probably be OK either way.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
05-25-2006, 10:20 AM | #4 |
yes I bought the stock length shocks for the front and all is good.
my questions were concerning the rear w/ the 4" drop. So flipping the brackets and swapping side for side will give me another inch or so if installed length then correct? I'm thinking the brackets won't sit flat against the trailing arm if upside down? You just make a spacer of some sort? Sounds like an easy/free solution ( I like free) The other alternative is running KYB 5409's in the rear...anyone doing this with a 4" drop that can confirm it works? thanks much guys
05-25-2006, 11:02 AM | #5 |
It has been a couple of years since I did this, but if I remember right, I cut the lip off the side that was interfering with the trailing arm, and welded a new piece of flat bar on the other side that help stiffen it up (red arrow). I ran stock length shocks, and had a 4.5" drop (3" springs, 1.5" blocks).
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 05-25-2006 at 11:04 AM. |
05-25-2006, 09:54 PM | #6 |
Just flip the lower mount and put a spacer between it and the trailing arm. Mines been that way for years. And stock length shock!
Smitty '71 Short Fleetside Spring Valley, Ca. |
05-25-2006, 10:12 PM | #7 |
No need for any flipping of anything. I am running the same setup 2.5" drop spindles in the front and 4" drop springs in the rear. I am using Doetsch drop shocks. I bought them from CPP, here is the part No. 4095GLL. When I was looking into lowering my truck eight years ago there were not nearlly as many venders as now. By the way the truck rides like a dream and handles well with these shocks. I hope this helps
http://www.doetsch-shocks.com/3.asp Last edited by 72 Cheyenne402; 05-25-2006 at 10:14 PM. |
05-25-2006, 10:36 PM | #8 |
But he likes free and easy...... mostly free. Shocks aren't free, flipping brackets is free. Leaves more $$$ for shiney LOL
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 05-25-2006 at 10:38 PM. |
05-25-2006, 10:50 PM | #9 |
Lol!!
05-25-2006, 11:11 PM | #10 |
67-72 Addict!
I'm running stock shocks on my newly lowered 4" rear with no problems whatsoever.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-26-2006, 12:20 AM | #11 |
I lowered one of my trucks 4" in the rear with coils and am running stock length shocks and it rides just fine.
Douglas.
-1968 Chevy SWB = Frame Off/383/Muncie Car 4 speed -1968 Chevy SWB = numbers matching 307/Truck 4 speed. -1966 Chevy II = 2 door No Post/130,000 Orig miles/230 6cyl/powerglide/Vintage AC -1972 Chevy Nova = 2 door/412 Small Block -1927 Ford Roadster = Homebuilt/widened 8"/350/ Custom Everything. |
05-26-2006, 02:41 AM | #12 |
Out of the carpool lane.
I use the 5409 all the way around it they're very comfortable. My drop is a 5/4
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
05-26-2006, 10:33 AM | #13 |
Jefe and 70c10:
You running stock length rear shocks correct? Or stock length front shocks (like the 5409's)? Thanks for the replies guys.... 72 Cheyenne - thanks for the part number.
05-26-2006, 12:24 PM | #14 |
67-72 Addict!
I'm running stock length all the way around. My front is lowered almost 3" by cutting the coils.
