![]() Join Date: Feb 2003
WTB: Leaf Spring Mounting Plates
I'm looking for front and rear mounting plates (plate with 4 holes where the u-bolts go through and sits on top of the leaf springs) with numbers 6274149 and 6274150 for the front (number stamped on top). Stock for 69-72 Blazers,K10 & K20 trucks. The rear numbers are 3762845 for both sides (numbers should be stamped on the outside of the axle bow of the plate. Came mostly on 20 and 30 series trucks from 55 to 72. Trying to build a numbers original truck or I wouldn't be so picky. Shipping is to 55060.
Thanks, Scott |
Re: WTB: Leaf Spring Mounting Plates
I think I have them. Not sure of the condition and won't be able to check until Sat when I got out to my shop. Pm me Sat morning to remind me, my memory stinks
I"ll shoot you a PM as soon as I get up. I also wanted to let you know that I found the right ones for the back but still need the front set.
Thanks, Scott |
no problem
Active Member
![]() Join Date: Nov 2002
If 72 Cheyenne K20 doesn't want the plate I would be interested. Let me know the total to 55901.
Don Brace 55 Nomad 56 Nomad 58 Impalla Coupe 58 Bel-Aire 4D HT 61 Impala CVRT 409 4 SP 2- 71 Longhorns Always looking for old toy trains, Juke boxes Pin ball and game machines. |
"Ochre Ogre"
Scott, I have the front mounts blasted clean. These are off the same truck that the rear brake backing plates came off of. I didn't compare the part number, but they should be the ones you need.
I have the back ones available also, just not blasted clean at this time.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
Sorry i didn't get back to you sooner, i was cleaning up all the crap and it took longer. The set I have are off a 67 and the part # is completely different
