![]() Join Date: Feb 2003
Front Leaf Spring Plate Bolt Hole?
I replaced the 4" lift springs in my truck with factory springs and noticed in the mounting plates there is a threaded hole for what looks like a 3/4" bolt. Does anyone know what this is for?
Scott |
Re: Front Leaf Spring Plate Bolt Hole?
That is where the front sway bar bolts to. They were on the 73 and up 4x4's.
I have not seen any on the 67-72 trucks but the sway bars could be retrofitted. Jim |
Thanks Jim, I just checked info on the plates. I looked at the rear plates and after getting all of the mud and crap off of them found that they are the corerect ones. I found a set of front plates in the basement with #'s 3943437 & 3943438. I figure they are pre 73' due to the fact that they don't have a threded hole for a sway bar to attach to. I know my parts book is dated on some parts but don't know if these are or not. If anyone has a newer version (mine is 9/72) could you do me a huge favor and look these numbers up for me and let me know what they fit. Should be in group 7.425 and listed as plate,anchor.
Thanks, Scott Last edited by 72 Cheyenne K20; 05-25-2006 at 09:02 PM. |
