Old 05-25-2006, 03:38 PM   #1
Blizz
Blizz's Avatar
any pics or how-to's on removing rockers?
I need to replace my rockers but I'm not sure where all I need to cut. I've also read that thre replacement floor pans have the inner rockers built in. I've already bought some inner rockers but I'm not sure where they go or if I need them.
Blizz is offline   Reply With Quote
Old 05-25-2006, 04:06 PM   #2
Jason915
Re: any pics or how-to's on removing rockers?
http://ebfabman.com/index.htm
Try this link ebfabman is a board member and a body fab God.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 05-26-2006, 09:59 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
The rockers have spot welds that need to be drilled out along the bottom lip I am not sure how the corners come off as I have not gotten that far yet... Yes the floors have the rocker backing plate built into them... I also have extra inner's...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-27-2006, 04:54 PM   #4
Blizz
Blizz's Avatar
Thanks French. I just found out that I'm gonna have to replace the kick panels too. I've read a bunch on floors and rockers.....even pilars but not the kick pans. How the hell do those come off? Should I do the whole thing or just the bottom piece that's actually rotted out?
Old 05-28-2006, 10:58 PM   #5
Scrubby
Check out GMTrucks.org
In general, you should only cut out and replace the bad portions of the panel. Repop panels don't always fit well, so only replacing the part that is needed will make the fit easier.
Scrubby is offline   Reply With Quote
