Questionable
need help reinstalling battery box
long story short -
i removed my battery box because of rust. i took off my front clip to work on my LS1 install. while the front clip was off, it fell over ![]() ![]() can some of the pros around here tell me what to do? i wanted to bolt it up while the front clip was still not yet mounted to the cab. once the battery box was in, i was gonna start getting the front end bolted on and put back together. THANKS!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 05-26-2006 at 11:02 AM. |
Cantankerous Geezer
Re: need help reinstalling battery box
When I put the new radiator support in my 69 the old battery box bolts didn't line up with the nutplates in the new support. Iirc, one hole was close, the other two were off. Had to drill new holes in the box.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
#3 | |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Questionable
It's OEM/NOS - has the part # stamped in it. The original one don't fit either - I had the same thought as you, might be aftermarket!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
TOTY 2006
![]() Join Date: Dec 1999
With mine, I had to push and pull to get every bolt started, and then once thatwas done, slowly tighten each bolt a little bit at a time.
I used a repop from ECE... |
Questionable
I think the problem is me removing the front clip with no battery box in. i believe it was keeping the innerfender/outerfender and core support in place, and when i took it off, everything shifted.
neither old or new fit. just curious if anyone else has had this same problem before.
Questionable
ttt
