Old 05-26-2006, 11:16 AM   #1
Ole Blue 68
Ole Blue 68's Avatar
Front Sway Bar?
I'm just about done with the engine so I'm starting to look at the suspension and steering. My first thought is to install a front sway bar but considering my 68 doesn't have one on it already, how hard is it to put one on? Can it be done out of my garage with hand tools?
Ole Blue 68 is offline   Reply With Quote
Old 05-26-2006, 12:06 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Front Sway Bar?
It's an easy job. TxFirefighter did a nice writeup in FAQ on this topic.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-26-2006, 12:15 PM   #3
Ole Blue 68
Re: Front Sway Bar?
Thanks Jim, I just checked it out and it looks pretty easy. The only thing is I'd have to figure out a way to pop that rivet on the crossmember without a torch or grinder.
Old 05-26-2006, 01:03 PM   #4
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Re: Front Sway Bar?
I used a sawzall to cut the heads of the rivets off, and a mini sledge hammer and a punch to knock the rivet out.
Toad
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 05-26-2006, 01:17 PM   #5
Orange
Licensed to Thrill!
Orange's Avatar
Re: Front Sway Bar?
I agree, it's a very simple straight forward install. No reason why you couldn't do it with the tool you most likely have a few hours of work. It was one of my more favorite projects.
Now, I just have to do the rear.
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 05-26-2006, 01:21 PM   #6
Ole Blue 68
Re: Front Sway Bar?
Alright, no sawzall either but I'm sure I can find something to take care of that rivet....
I got a rotozip and I think they sell a metal cutting wheel attachment. That should work don't you think?
Old 05-26-2006, 01:35 PM   #7
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: Front Sway Bar?
I drilled the rivets out, centre punch the head, start with a small drill and work your way up to a big un and then BFH and chisel and off it pops and then just punch it through. I followed TXfirefighters writeup and also used the ECE lifted brackets as they brackets mine came with had seen a few kerbs in their time and had been welded up here and there. Swaybar came off a mid 80's wrecker that someone was breaking over here that I think started life as a camper so is about the thickest you can get. Took me an hour or two to mount up from start to finish.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 05-27-2006, 08:53 PM   #8
Aarons72s
Re: Front Sway Bar?
I used a rotozip to get the rivet head off of a cab mount with the cab still on the frame. Then I just drilled it out. I hope this helps. good luck.
Aarons72s is offline   Reply With Quote
Old 05-27-2006, 09:32 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Front Sway Bar?
You could rent a grinder at an equipment store or a trailer (not u-haul) rental or mower reantal type place.
Old 05-27-2006, 09:33 PM   #10
Longhorn Man
Re: Front Sway Bar?
Or, you could get a cheap one from harbor freight. I think they have them for like 20 bucks ort something, and it may even last long enough to finish the job. (it falls in there total junk tool catigory, but if it makes it through the job, then it was money sorta-well spent)
Old 05-27-2006, 10:18 PM   #11
57sailplane
57sailplane's Avatar
Re: Front Sway Bar?
3 lbs hammer and chisel. chisel head off rivet.. then a hole punch drive the rest trough.. i used this process to take the drums off the hub..
57sailplane is offline   Reply With Quote
Old 05-27-2006, 10:30 PM   #12
cableguy0
Re: Front Sway Bar?
i bought a harbor freight angle grinder for like 15 bucks on sale and havent been able to kill it. i purposely abused it to see if i could kill it because i got the warranty on it and it keeps on tickin.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 05-27-2006, 10:50 PM   #13
Longhorn Man
Re: Front Sway Bar?
Wow, I killed 2 of them, both the first time used.
They were both purchased at a yard sdale, so there's no tellin what was up with them... but they wqere both unused though.
