Old 05-26-2006, 06:28 PM   #1
Chevrolet4x4s
Chevrolet4x4s's Avatar
Airbag?????
Do airbags help these trucks handle better when used in conjunction with normal suspension?
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 05-26-2006, 08:00 PM   #2
XXL
Seņor Member
XXL's Avatar
Re: Airbag?????
Not particularly. What are you trying to accomplish?
XXL is offline   Reply With Quote
Old 05-26-2006, 11:22 PM   #3
Chevrolet4x4s
Re: Airbag?????
Nothing in particular just thinking about how cool it would be to build a 2wd slightly lowered(2.5/4)that would handle like a sports car(well mabe not that good)and wondered if air bags would help
Shane
Member#20327
Old 05-27-2006, 08:22 AM   #4
XXL
Seņor Member
XXL's Avatar
Re: Airbag?????
You'd be better off going with springs, sway bars, and various other stiffening components. Air bags' real purposes are to 1) adjust suspension height on the fly, or 2) provide for overload capabilities on demand. Neither really deal with "sports car handling" per se.
Old 05-27-2006, 10:44 AM   #5
Chevrolet4x4s
Re: Airbag?????
Shane
Member#20327
Old 05-27-2006, 08:03 PM   #6
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: Airbag?????
It all depends on the set up. If your not looking to lay frame you can set up an airbag suspension to handle as well or better as a static one
There were two guys on a different board that had similar chevy trucks and similar goals of handling and one used bags and the other used static.
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 05-27-2006, 11:53 PM   #7
Chevrolet4x4s
Re: Airbag?????
Kind of what I thought...........Bench racing in my mind.
Shane
Member#20327
Old 05-28-2006, 08:29 AM   #8
XXL
Seņor Member
XXL's Avatar
Re: Airbag?????
I disagree. As the bags get compressed and decompressed at every bump and turn, the air inside heats up. Heated air expands (was that Charles' or Boyle's Law?... I think one plagiarized the other ). When the air expands, you've got a significant change in bag behavior. Not so for traditional wound springs. While the spring rate does change as the coils heat up, the change is insignificant, and that heat dissipates almost as quickly as it is generated, thanks to the spring acting as its own heat sink.
Old 05-29-2006, 08:14 PM   #9
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: Airbag?????
If the air heats up and expands it will just make the ride stiffer. I'm not shure how much it would affect it real world but it seems like a plus being tighter. I figured the main problem you would have would be it being too soft. Plus I would like the ability of more adjustment unlike what you would get being with a traditional suspension.
Old 05-29-2006, 08:31 PM   #10
XXL
Seņor Member
XXL's Avatar
Re: Airbag?????
If stiffer is always better, then we'd all use 2x4's instead of bags or springs. However...
Old 05-29-2006, 08:36 PM   #11
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: Airbag?????
Old 05-30-2006, 07:54 PM   #12
Chevrolet4x4s
Re: Airbag?????
Thias is getting interesting
Shane
Member#20327
Old 05-30-2006, 09:51 PM   #13
7T7
Regular guy
7T7's Avatar
Re: Airbag?????
Shane
Compared to most stock suspensions.....definitely!
Compared to "normal suspension" well........jump over to this link and read what Popular Hot Rodding had to say about air suspension.
http://popularhotrodding.com/tech/0603phr_air/
I'm may be a little bias because I happen to love air suspension.
If I were building for pure road course/ auto cross, coilovers would be the plan.
However for street, it would be air. Such a great ride and handling to boot!
I'm not looking to start a big debate here, I'm just giving a you my thoughts on the subject..
'Frank'
77 Silverado
18 & 20 American CL205s
Edelbrock MPFI, 700r4, Baer Brakes
9" F@rd rear, Vintage air, Bags etc etc..
7T7 is offline   Reply With Quote
Old 05-30-2006, 10:46 PM   #14
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Re: Airbag?????
XXL is a masterdebater
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 05-31-2006, 08:47 PM   #15
XXL
Seņor Member
XXL's Avatar
Re: Airbag?????
Wrong smiley... :happy:
Old 06-01-2006, 08:14 PM   #16
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: Airbag?????
I agree I would probably stick with the coilovers for road cores also
You can have the best of adj ride hight and handling. Show and Go
Is there any other way?
Old 06-30-2006, 05:07 PM   #17
JayG
Formerly ADHDCARGUY
JayG's Avatar
Re: Airbag?????
My '67 is lowered 5/7. Stock style springs in front, only shorter, sleeve bags in back on ladder bars with large front and rear sway bars. I went from coil-overs in back to sleeve bags because my "honey" couldn't handle the awful bouncing of the coilovers(they were like an old 4x4 CJ4 Jeep), she has slight neck issues. Might have been the wrong rate coils, I don't know. But, the truck handles like it's on rails, rides very nice, and I can increase the air pressure when I loadup for a road trip and the ride stays the same. With some forthought, a bit of fabricating, and not alot of money(always my case), a person can have the best of both worlds, Good ride and good handling! IMHO
Jay
67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C.
54CHEVY - BURB, beginning construction(well, i gotta take it apart first!)
36FORD PU - WAITING
38CHEVY - 2DR SD,CHASSIS FINISHED
46CHEVY - BURB - waiting
JayG is offline   Reply With Quote
