Old 05-27-2006, 11:26 AM   #1
boatpuller
boatpuller's Avatar
what driveline do you have?
hey,anybody go from 2 piece to a 1 piece driveline?on a swb.i've been having some issues after lowering. first some vibration caused by angles with my 2 piece. we calmed it down by reducing carrier bearing bracket height .now i'm getting a leak,i wonder if the driveline is to long now?what if anything did you low guys have to do?
boatpuller is offline   Reply With Quote
Old 05-27-2006, 11:15 PM   #2
1badbowtie
Re: what driveline do you have?
Your rear flip kit has offset holes to adjust your pinion angle, did you install them backwards??
1badbowtie is offline   Reply With Quote
Old 05-28-2006, 11:57 AM   #3
boatpuller
boatpuller's Avatar
i don't think so had schwabs install it.the guy that did it has done a bunch of them.you running a 1 or two piece driveline?like to hear some feedback from guys that have went to 1 piece and if there happy.
Old 05-28-2006, 12:22 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
My short bed and my Son's both came with a 1 piece drivelines and we have had no issues with the angles---did not have to install angle shims. Make sure that you get the driveline made at the right length, so it does not fit into the tranny yoke wrong. Measure twice to be sure.
piecesparts is offline   Reply With Quote
Old 05-28-2006, 04:44 PM   #5
SSC's76
No No
SSC's76's Avatar
Ive never seen a SWB with a 2 peice shaft.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 05-28-2006, 05:48 PM   #6
piecesparts
Come to think of it, neither have I.
Old 05-28-2006, 08:34 PM   #7
boatpuller
boatpuller's Avatar
i got one.maybe cause it was born a diesel.but i have heard of others.don't ask me why.that's what i'm trying to figure out.
Old 05-28-2006, 09:05 PM   #8
piecesparts
What I would do at this point is go get a driveline from a salvage long bed and when you lower your truck, have that long shaft cut and balanced to the length that you will need. You are going to have to cut one to length for the lower attitude anyways, might as well have the long driveline to make it where you want it.
Old 05-29-2006, 01:09 PM   #9
magnethead
7000 #'s of american IRON
magnethead's Avatar
same here
magnethead is offline   Reply With Quote
Old 05-29-2006, 08:22 PM   #10
boatpuller
boatpuller's Avatar
wow,guess i'll have to crawl under there and post a pic.i can't believe i got the only one.no wonder i can't find much info on swapping to a one peice.
Old 03-23-2007, 09:22 PM   #11
bigblock79
67 Chevy Stepside
bigblock79's Avatar
all big block trucks came two pieces and diesel i think
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 03-23-2007, 09:29 PM   #12
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Well I dont know if its the same but my long bed truck is a two peice. It a factory 305 manual. And my other long bed started off as a 305 automatic. I dont know if manual and auto make a difference or if a long bed is different.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
