Like a Rock!
Temp gauge needle
I have a spare cluster and noticed the needle on the temp gauge feels flimsy. Is that normal?. I took it apart to clean it up and I can move the needle back and forth with no resistance like the oil gauge. Just curious do these really go bad?
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
![]() Join Date: Jul 2000
Re: Temp gauge needle
It's OK for the needle to move easily with no electrical current applied.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#3 | |
Outlandish Trends - FL
-Bret 67 short-fleet sold! |
Like a Rock!
Thanks. The needle on my other cluster stays in the middle. This one lays to the right a little or left a little if you push it that way. Is there any way to test a temp gauge while it's out of the cluster?
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() Last edited by c10crazy; 05-28-2006 at 01:55 PM. |
Hmmm, that would be tough I'd imagine. You'd have to have power to it somehow, and then if you did that I guess you would have to hook up the sending unit to it and drop it in some hot boiling water maybe? Dunno, never tried it.
![]() Join Date: May 2005
Isn't your sending unit basically a resistor? The hotter the water, the better the circuit? Try it with 6 volts or 9 volts, see what happens
just don't let the smoke out of it... It's the smoke that makes it go!..
Avatar is a pic of "Before"... Just wait.. ---------------- 1969 Fleetside: Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans. 20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit). Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all ---------------- Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!! ![]() |
Actually, the sender's resistance decreases as the temp increases. This means more voltage is dropped across the temp gauge, defecting the needle to the right. If you have a 12 volt bench power supply and some resistors from Radio Shack, you can test the gauge, but first you need to know the sender's resistance at various temps. I used to have it written down somewhere for 2 or 3 temps, but can't find it.
