rebuild or replace 283 v8
Just seeking opinions and advice on whether a '66 C10 with a 283 v8 has the capacity to make moderate amounts of HP. I'm not expecting anything huge, but is this block capable of making something in the ballpark of 300hp (without nitro or forced induction)? I know the stock 283 supposedly tops out around 170hp, and I assume that with some minor mods could get near 200.
There's a chance that this engine might need to be rebuilt and I'm just wondering if it's worth the effort. Thanks (again) |
Re: rebuild or replace 283 v8
rebuild it! i rebuilt mine pretty much stock and i love it.
65 c10 tore apart 70 c10 305/350th |
I would keep it also
For those tracking my progress with this truck, here's a pic I took of it after getting it ready for transport:
if it needs rebuilt a 350 will swap right in.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
A 350 is not as cool as a 283 ether tho.
I would bet that if you look close and run some numbers on that motor you will find that it has powerpac heads on it. If they are that means you have 60cc combustion chamers. The valves are kind of small in these heads but if you put a beter intake, carb and headers you will find a noticible difference in performance. I would also recommend going with an HEI and an internal voltage alternator/regulator. The 283 was a great little motor with a lot of rev potential. I would keep it. For about 600 dollars you could have a respectable motor. All of this depends on how solid the bottom end of the motor is. Are you burning any oil or hearing any knocks?
JRB Last edited by JRB; 05-28-2006 at 11:30 PM. |
#8 | |
The big limitation on the heads are the Valve size. The 60cc heads just mean it has a higher compression ratio because of the smaller chamber size on the heads. I think though (Bang for buck) would be the HEI and an Edlebrock Performer Intake and a four barrel. Does the truck have a four barrel or two? Cams are cheap and do give you more performance but remember your working with a 40 year old motor so you may want to look at having the heads gone through and at least new valve springs and hardend seats before you go to a cam. I am sure you have rams horn exhaust manifolds so if you even went to a shorty header you would see an improvement from them. Wish you luck with your project.
JRB |
#10 | |
I realized today now that I'm home that my garage was quite trashed and was in need of some spring cleaning. I can't wait to get this truck home ![]() |
Keep the 283 v8
Looks like a good project. I'm in Denton 940-206-8483
1965 SWB w /283 3 speed I'm wprking on a 700r4 conversion |
You are at the right place here! You will get more opinions than you need but you will also get more great information than you could ever expect! Opinion time-- on that 283--If you don't want it-- you will find lot's of interested buyers
#13 |
Prestige member Old Farts Club
good motor - likes to rev- use a 4:10 gear for power and an overdrive for economy. duel exhaust, 650 cfm 4 bbl, HEI or electronic conversion kit ,clevite 77 bearings , cam for allot of power use comp xe-262 or equal. Just don't go too big on anything and you'll have allot of power (fun).
Hey sombodys gotta do it! ![]() |
#14 | |
Also, if the bottom end (stock) turns out to still be solid, is it worth the effort to take it apart and put in new bearings? I guess I'm asking what the consequenses of spinning an old bearing are. As per other suggestions, I'd hate to overstress the old block by overdoing it, but I do want to have much fun, so I'm willing to risk it a bit ![]() |
#15 |
![]() Join Date: Apr 2001
if your looking ot go overdrive, I have a 2004r out of an 84 olds station wagon and love it... have less than 500 in the swap in my 74 c10 (and that was with the trans freshened) and cruise all day long at 75 @ 2200 RPM... pulls about 16-18mpg with a 305, 4bbl q-jet, and 3.73 on 31x10.5 bfgoody long trail ta's.... more food for thought...
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
#16 |
I would actually be quite happy with a 4- or 5-speed manual with a floor shifter. Do they make one that will relatively easily swap in?
#17 |
I have heard of people putting in a 5 speed from S10 model. Not sure which one it is but I think it was relatively cheap. But my Idea of cheap is anything less than $1000 is cheap. Have you looked at the FAQ String to see if there is any information on a 5 speed convertion?
JRB |
#18 | |
Some basic FAQ searches didn't turn up much info aside from the auto trans/overdrive upgrade (700r4?) which I'm not looking for. I'll check again looking for an S10 trans swap. |
#19 |
JAVA,
I picked up my 200r4 out of a Olds stationwagon and actually drove it before I bought it for $300, I know there is a couple of kits that you have to install in the Tranny that cost another $150 before you would put it in your truck. I think a crossmember for it is around $100. Than means you could be in a 200r4 for about $500 to $600. The only other thing you would have to do is get a yoke for a 200r4 and have your drive shaft modified. I think a 200r4 is very doable for under $1000. I am going to put mine in my 67 eventually once its shortened. Good luck again with your project. JRB |
#20 | |
I found something funny when googling for more information about it: 200R4 (Olds)Transmisson Core or Parts - $50 Came out of my low mileage 1985 Oldsmoblie Hearse. Has 80,000 orginal miles (the first 60,000 were really slow) when drive and overdrive quit working, other gears worked fine. ![]() |
#21 |
I'm just now realizing that the 200r4 is an automatic trans.
#22 |
try a S-10 site, they do V8 conversions maybe someone ran a stick too
#23 |
i was wondering where to get good high quality bottom end parts i have to rebuild mine it is a 283 from 63 to 65 and has the power pack heads a 600 cfm carb (a bit to much carb 4 a mostly stock engine) it ran low on oil after having it in the shop haveing the rear main seal replaced and oil pan i want more power from it
#24 |
![]() Join Date: Sep 2005
www.northernautoparts.com is a great place for rebuild kits you should be able to get a reman crank at any parts store or have your remaned at any machine shop
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#25 |
![]() Join Date: Apr 2007
283s are cool motor and you hip up the HP. on them..
283 the mighty small block ![]() |
