Old 05-28-2006, 09:45 PM   #1
tommyd34
350 oldsmobile engine swap
a friend of mine has a oldsmobile engine and want to put it into a 81 chevy 3/4 ton 4x4 was wondering if the mounts would work from a 350 chevy engine or do you have to get the mounts for the 350 diesel
tommyd34 is offline   Reply With Quote
Old 05-28-2006, 11:52 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: 350 oldsmobile engine swap
I have not done it, but I have seen others on the board say that you need Diesel mounts.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 05-29-2006, 05:57 AM   #3
tommyd34
thanks for the reply slonaker
Old 05-31-2006, 04:54 AM   #4
the baron
the baron's Avatar
hi Tommy ,
fitting an Olds engine instead of a Chevy engine won't work just like that ...
the tranny patterns are different , so you'll need a BOP ( Buick , Olds , Pontiac ) tranny , unless you have one of those rare "universal trannies" ( which fits BOP & Chevy engines ) , but they were only released in the eighties , I think ...
The only trannies you'll find for your 4X4 truck to be fitted with an Olds engine are indeed the TH400 which were coupled to the 350 Diesel engine ( 1977-1981 )
for the engine mounts , any Olds engine mounts will do the job , not only Diesel mounts ...
Cheerzzz
the Baron
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016
1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D.
1960 Girl Friend , frame still good , body has some dents
the baron is offline   Reply With Quote
Old 05-31-2006, 05:11 PM   #5
rockman20
"The dude abides"
rockman20's Avatar
They do sell adapter plates to fit a Olds engine to a Chevy tranny. If you are inclined enough, you can also make one as well.
From what I can remember, you will need the olds mounts. the baron is right that any Olds mounts will work. I have always wanted to plant an Olds in a Chevy. I love Chevy, but I just don't seem to have the luck with engines like I have with Olds. I would love to put a 455 under the hood of a Chevy truck. The Olds have some wicked torque which is exactly what I want in a truck.
Good luck and let us know how it goes!
RockMan
1993 Chevy Silverado C3500 1 ton dually
1994 Honda Civic
1969 Oldsmobile Cutlass S
1953 IH Farmall Super M
New to the fleet:
1992 Subaru Loyal
rockman20 is offline   Reply With Quote
