Old 05-28-2006, 11:24 PM   #1
C&C Chevy
C&C Chevy's Avatar
Question on header diameters..
1 1/2", 1 5/8", 1 3/4" These are the most popular primary tube sizes for headers.
What's the difference for each primary tube size? What's the best application for each? Is bigger always better? Just curious.
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 05-29-2006, 12:12 AM   #2
f.monroe
f.monroe's Avatar
Re: Question on header diameters..
I am sure someone will give you a more specific answer but bigger isnt always better . A stock engine wont perform as well with a larger diameter header as a well built engine . Too large of primary tube will not provide enough back pressure and will cause problems . I have heard of engines running hot due to using too large of a primary . If your engine is stock to mild , I would use the regular 1 5/8" tubes . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 05-29-2006, 10:21 AM   #3
SSC's76
No No
SSC's76's Avatar
Wow mention of 1-1/2" headers, thats a small pipe not suitable for anything over 300 cu or with any modifications.
A stock/mild 267-305 will usually be fine with 1-5/8" headers, step up to a cam with over .400 lift and your going to want the 1-3/4" headers. A 327-400 will benifit most from 1-3/4" even stock smog engines. Usually 1-3/4" will flow well for an engine to the 400 hp range then you step upto the 1-7/8" might even want to go to the 2" or the 2-1/4" after that.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 05-29-2006, 01:01 PM   #4
magnethead
7000 #'s of american IRON
magnethead's Avatar
it think mine has 1 7/8ths" primary's....
magnethead is offline   Reply With Quote
Old 05-29-2006, 07:49 PM   #5
C&C Chevy
C&C Chevy's Avatar
That sucks about the 1 1/2". Seems like most of the headers under $150 are 1 1/2" primary kind. I guess I'll start looking for a 1 3/4" primary tube header.
Robert
Current:
Past:
Old 05-29-2006, 10:46 PM   #6
Karl Hoh
A little east of nowhere
Smaller primary tubes help low end torque. If your engine is stock or very mild, I would run 1 5/8. We ran 1 3/4 and 1 7/8 on a 480hp camero bbc drag car. My 2 cents.
68 C10 250 4spd
69 C20 327 4spd
69 910 250 3spd
80 K10 350 4spd
76 C60 366 5spd school bus
"THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR"
Karl Hoh is offline   Reply With Quote
