Old 05-29-2006, 12:02 AM   #1
Kager67
what knocking sound?
Kager67's Avatar
th400 Q
I have a question about the th400 in my 67. Last fall before I put it away for the winter I took it out for one last drive. Everything was going good until I took off from a stop sign and it wouldn't shift from 2nd to 3rd. I stepped on it and when the rpm's got to around 4 grand it shifted(and shifted hard). Fast forwarding to this spring, it started doing it again. The only thing is now that it doesn't even want to shift out of first without revving it up. My first thought was the modulator, but I hate to just throw parts at it. The other thing that could be a possibility is that it has a aftermarket dipstick in it. It does leak a bit so I have to add a couple times a year. I'm just wondering if it could be off and I am over/under filling it. Just seeing if anyone out there has had the same problem and could give me some advice. Thanks
Kager67 is offline   Reply With Quote
Old 05-29-2006, 01:12 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: th400 Q
Look to see if the vacume line is actually on the mod... any leak in this line would cause your problems.
If the line is fione, that would be the first thing to chainge, and it wouldn't really be throwing parts at it, as it does in fact controll the upshift.
Old 05-29-2006, 12:46 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: th400 Q
Check to see if the kickdown switch is not stuck in the closed position. I think its on the carb. Low fluid and sticky govenor weights can cause shifting problems. There are other causes too but they are more expensive.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
